Vista - Problem with sleep & hibernate
Old 05-10-2008   #1 (permalink)
swalker
Why is programming a computer so that sleep and hibernate works like
they should so difficult. Every time my Vista Home Premium system
takes a long nap it refuses to wake up. Had the same problems with
other MS operating systems.
Surely by now MS could have fixed this problem.
Old 05-11-2008   #2 (permalink)
Rick Rogers
Re: Problem with sleep & hibernate
The problem stems from the hardware driver files, of which there are
hundreds. If even one of them does not support the sleep function correctly,
the it won't work. Microsoft supplies a large number of these in the
operating system, but many are also supplied by hardware manufacturers and
they all need to work together for this function to be successful.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"swalker" <sw@xxxxxx> wrote in message
news:c0rc24ln696asf9n6ti3btkqvcqcsfdc7k@xxxxxx
Old 05-11-2008   #3 (permalink)
Quote  Quote: Originally Posted by swalker View Post
Hi Swalker,
You might try this to see if it can help you.
Power Options and Sleep Mode Problems
Windows Hibernate sleep wake up problem General Discussion
different between sleep and hibernate Vista General
problem with sleep mode and Hibernate Vista General
Vista Sleep / Hibernate and Internet Connection Problem Vista hardware & devices
RE: Vista Sleep / Hibernate and Internet Connection Problem Vista hardware & devices
