How long does System Restore take?
  1.    26 May 2006 #1
    Lang Murphy Guest
    Doing a system restore and it appears to be hung on the "Windows is
    preparing to shut down..." blue/green swirly screen... HD light has been
    pegged, with minimal flickering, for close to 20 minutes now... that seems a
    bit long...
  2.    26 May 2006 #2
    Andre Da Costa [Extended64] Guest
    Re: How long does System Restore take?
    System Restore usually takes the same amount of time as a restart of
    Windows.
    Andre
    Windows Connected | http://www.windowsconnected.com
    Extended64 | http://www.extended64.com
    Blog | http://www.extended64.com/blogs/andre
    http://spaces.msn.com/members/adacosta
    "Lang Murphy" <langmurf@bellsouth.net> wrote in message
    news:%232M3cCQgGHA.1856@TK2MSFTNGP03.phx.gbl...
    > a bit long...
  3.    26 May 2006 #3
    Henry Guest
    Sounds like it's not working correctly, what number beta are you using. most
    of the early ones didn't. I did a restore on 5384.4 and it worked.
    > a bit long...
  4.    26 May 2006 #4
    Lang Murphy Guest
    Well... it took about 30 minutes, but I finally got the log on screen... but
    getting error that system restore did not complete successfully... no
    changes to files and settings... bummer.
    > a bit long...
  5.    26 May 2006 #5
    Lang Murphy Guest
    5384... and it didn't work... sigh...
    "Henry" <Henry@nomail.com> wrote in message
    news:O9F%23zGQgGHA.3996@TK2MSFTNGP03.phx.gbl...
    > most of the early ones didn't. I did a restore on 5384.4 and it worked.
    >> seems a bit long...
  6.    26 May 2006 #6
    Tony Sperling Guest
    I did this once in x64, it took 30 minutes to establish that the restore
    point didn't work. I kept on picking dates further back in time and each
    time it took 30 minutes, but when it finally hit a date that worked it took
    less than 20 sec's.
    Tony. . .
    news:OJB0fJQgGHA.3588@TK2MSFTNGP04.phx.gbl...
    > but getting error that system restore did not complete successfully... no
    >> seems a bit long...
System Restore - taking too long?
Hi Guys I have looked through the discussions and run the tutorial and not found anything to help me! :cry: I was trying to do a system...
General Discussion
Paragon - long time to restore
Paragon Drive Backup 8.51 Personal Edition I have a old backup made in XP on a stationary computer. Now im restoring it on my laptop with Vista on...
Software
System restore doesn`t keep store points for long
My ASUS laptop is nearly a year old & running Vista home premium, but it`s never kept restore points for longer than two or three days. I recently...
General Discussion
System Restore Point - how long
How long should a sytem restore take on vista 64? All it says is - System Restore is initialising I am restoring from yesterdays fresh install...
General Discussion
System restore process takes a long time
When I restore system with this tool I wait arounf hour or two hours when this process finished. And I don't know how long time this process might...
Vista General
RE: System restore point - long time.
I am having the same problem - especially when it is trying to install updates from windows. It is taking over an hour. I don't think this is...
Vista General
system restore not creating system restore everyday
Ok I look at the system restore today and it did not create any system restore point automatically. I though system restore automatically create a...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
