BSOD: irql_not_less_or_equal
  1. #1
    Snegithan's Avatar
    Newbie
    Singapore
    Vista Ultimate x64
    Local Time: 09:18 AM
    singapore
    Hi Everyone,
    I am using a Acer 5920G notebook which was loaded with Vista Home Premium x86. I have format the factory default image/partition and reinstalled Vista Ultimate x64. I am using the drivers which are provided by the notebook manufacturer for 64bit Vista editions. I feel the system is running smooth and stable and I also never notice any errors on the event logs but I have this BSOD (irql_not_less_or_equal) problem which happens 2 times within past 2 weeks. When the first BSOD happens 1 week back I don’t manage to record down the error message or the snap of error BSOD. So I disable the auto restart on BSOD function in advance properties. I encounter the same problem yesterday for second time. I have uploaded the BSOD snap and as well as the minidump. Can someone advise me how I can solve the BSOD problem? Even it’s happen once in a blue moon but I feel uncomfortable with it.
    System Specs
    Intel C2D T7500 (2.2GHZ)
    Nvdia 8600M GT
    4GB RAM
    250 HDD
    BSOD SNAP (http://www.geocities.com/tamilstrike2k/dsc00031.jpg)
    BSOD minidump (http://www.geocities.com/tamilstrike...i051408-01.zip)
    Thanks in advance guys
    Rgds,
    Snegithan
  2. #2
    Gumby Guest
    Re: BSOD: irql_not_less_or_equal
    Snegithan <guest@xxxxxx-email.com> wrote in
    news:c0d48c978245c3f2448b5d1ceb805ac7@xxxxxx-gateway.com:
    > System Specs
    > Nvdia 8600M GT
    > 4GB RAM
    > 250 HDD
    That error usually means a hardware issue. Install the latest Nvidia
    drivers. If that doesn't fix it then it may be a Power Supply issue not
    providing enough power for the video card.
BSOD: irql_not_less_or_equal problems?
Virtual PC and IRQL_NOT_LESS_OR_EQUAL BSOD AMarshall Virtual PC 1 01 Apr 2010
Irql_not_less_or_equal BSOD (0xA...) Curufin Crashes and Debugging 16 21 Jun 2009
x64 BSOD irql_not_less_or_equal mickhames Vista General 2 08 Dec 2008
Bsod irql_not_less_or_equal RichTaylor1974 Vista performance & maintenance 5 09 Nov 2008
BSOD irql_not_less_or_equal piotrek.lewandowski@gmail.com Vista General 1 07 Aug 2007
