Vista Tutorial - HELP! Download Problems
Old 05-15-2008   #1 (permalink)
Santiago Azpilicueta
Guest
Had same problem. It was AVG 8.0. I had run out of trial time on it, so the program itself was not starting, but there was a freaking toolbar messing things up... Uninstalled AVG, and all is good. Hope that helps. Bottom line, try unistalling any anti virus, anti spyware, or anything of sorts.
And by the way, Kevin, your answer is like if you went to the doctor because of a pain in the little finger, and he suggested to cut it to get rid of the pain...
"... He Could Have Saved A Lot Of Money ..." is the most useless information you could had provided anyone, I would tend to agree with Karyn.
Download problems Network & Sharing
Download Problems Vista General
download problems Vista General
RC1 Download problems Vista General
