| | wordpad problem While using wordpad, I can access the font menue and select a different font or font size but when I look into the wordpad window or look at a print-out from the printer, the font and font size is always the default. Your suggestions please. |
| | Re: wordpad problem "b11_" <b11@xxxxxx> wrote in message news:3A7D84E7-900D-499D-AAA2-CC9B5398E33C@xxxxxx Quote: > While using wordpad, I can access the font menue and select a different > font > or font size but when I look into the wordpad window or look at a > print-out > from the printer, the font and font size is always the default. Your > suggestions please. You need to select the text before changing the font type in the menu. Try pressing CTRL+A to select all text, so that you get the idea. ss. |
| Problem with WordPad - how do I remove this unusual thing appearing in the File Menu? | General Discussion | |||
| wordpad | Vista General | |||
| WordPad | Vista performance & maintenance | |||
| WordPad problem | Vista General | |||
