| | Customize Notification Icons: How to get settings to stick? Hi, One thing that didn't work in XP and doesn't work in Vista is customising how notification icons should be handled in the sys-tray. The problem isn't that it doesn't work initial+ly, it's just that after a reboot or two most of the settings are "forgotten" and I have to set it again in "Customise Notification Icons...". I have noticed that the setting stick for some programs and not for others whatever I do. I wonder if it could be because the program alters it's sys-tray icons properties slightly every time it starts making Windows not recognise it? One program that is impossible to set is Avira Premium Security Suite. Regardless of how I set it it's forgotten after next reboot or restart of the program. -- //ceed |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Customize Notification Icons: How to get settings to stick? Hi, One thing that didn't work in XP and doesn't work in Vista is customising how notification icons should be handled in the sys-tray. The problem isn't that it doesn't work initial+ly, it's just that after a reboot or two most of the settings are "forgotten" and I have to set it again in "Customise Notification Icons...". I have noticed that the setting stick for some programs and not for others whatever I do. I wonder if it could be because the program alters it's sys-tray icons properties slightly every time it starts making Windows not recognise it? One program that is impossible to set is Avira Premium Security Suite. Regardless of how I set it it's forgotten after next reboot or restart of the program. -- //ceed If you mean for tham to be hidden or to show in the notification area, then you might also check in the program's settings for a option to uncheck to turn off from showing in this area. When a program has this option, it can sometimes override what you have selected in the Notification Area settings. Hope this helps, Shawn |
| Put settings on USB Stick | Vista networking & sharing | |||
| Vista desktop icons won't customize | Vista performance & maintenance | |||
| Customize notification icons settings lost after a few hours. | Vista General | |||
| Notification Icons - Customize | Tutorials | |||
| System notification icons & pointer settings won't stay put! | Vista General | |||
