Vista - easy way to transfer applications from XP machine to Vista machine
Old 05-17-2008   #1 (permalink)
eganders
I have an XP system with a lot of applications. I ordered a new
laptop that will come with Vista. I would like to be able to transfer
all my applications as seamlessly as possible to the new system. What
is the best way to accomplish this?
Example of applications:
Word, Excel, Access, Outlook (with connection to Pocket PC)
Visio
Photoshop
Quickbooks
Card Scan
Streets & Trips
ACDSee
and about 15 to 20 other specialized programs from DVD editing
programs to TV remote editors to speaker design programs.
It will probably take me days of time over a couple of months to get
these programs reloaded on the new machine, with the possibility of
some of them not working properly either due to compatibility problems
with Vista to having original disks to programs that have had updates
(automatic or otherwise) that will have to be updated again by going
to the site and getting the updates.
Is there a program, programs or a procedure that you-all can recommend
that will make this LESS painful. Oh, I know it will be painful. I
just want it to be LESS painful.
Thanks in advance!
(microsoft.public.windows.vista.general)
Old 05-17-2008   #2 (permalink)
Not Me
Re: easy way to transfer applications from XP machine to Vista machine
For each program, make sure it is Vista Compatible.
Install from the original media, find installer, right click and run as
administrator
I prefer to install somewhere other than the default location of Program
Files as MS has locked this folder down in Vista and many older programs
malfunction when installed there.
If all else fails, install programs in compatibility mode.
Once the programs are installed, you can try the Easy Transfer Wizard to
move your data, but it doesn't always work.
A Professional Amateur...If anyone knew it all, none of would be here!
CarGodZeroOne@xxxxxx
Change Alpha to Numeric to reply
"eganders" <eganders@xxxxxx> wrote in message
news:125eec08-3a43-4d23-8a92-53cc017fdbf8@xxxxxx
> Visio
> Photoshop
> Quickbooks
> Card Scan
> Streets & Trips
> ACDSee
> Thanks in advance!
Old 05-17-2008   #3 (permalink)
Rick Rogers
This should help:
How to use Windows Easy Transfer Companion to transfer programs from Windows
XP with Service Pack 2 to Windows Vista
http://support.microsoft.com/kb/931696
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
> Visio
> Photoshop
> Quickbooks
> Card Scan
> Streets & Trips
> ACDSee
> Thanks in advance!
Old 05-18-2008   #4 (permalink)
eganders
Re: easy way to transfer applications from XP machine to Vistamachine
On May 17, 9:17*pm, "Rick Rogers" <r...@xxxxxx> wrote:
Quote:
> Hi,
> This should help:
> XP with Service Pack 2 to Windows Vistahttp://support.microsoft.com/kb/931696
> Best of Luck,
> Rick Rogers, aka "Nutcase" - Microsoft MVPhttp://mvp.support.microsoft.com/
> Windows help -www.rickrogers.org
> My thoughtshttp://rick-mvp.blogspot.com
> "eganders" <egand...@xxxxxx> wrote in message
Quote:
> >I have an XP system with a lot of applications. *I ordered a new
> > laptop that will come with Vista. *I would like to be able to transfer
> > all my applications as seamlessly as possible to the new system. *What
> > Visio
> > Photoshop
> > Quickbooks
> > Card Scan
> > Streets & Trips
> > ACDSee
> > that will make this LESS painful. *Oh, I know it will be painful. *I
Quote:
> > Thanks in advance!
Quote:
> > (microsoft.public.windows.vista.general)- Hide quoted text -
> - Show quoted text -
Thanks Rick. This just may be what I am looking for!
Old 05-18-2008   #5 (permalink)
eganders
> administrator
> CarGodZero...@xxxxxx
I am not familiar with the Easy Transfer Wizard and am not sure what
"compatibility mode" is. Is the Easy Transfer Wizard loaded on XP &
Vista machines or do you have to get it off the Microsoft site? What
programs are considered to be "older"? The oldest I probably have
that I really need are no older than 2000.
Vista Machine unable to print to Printer attached to 98 machine thru parallel port Network & Sharing
Easy transfer autoloads on my XP machine Vista General
Easy transfer on my XP machine autoloads Vista General
How do I transfer Vista to a different machine? Vista General
Windows Easy Transfer (migwiz) hangs on install to source machine (XP) Vista installation & setup
