| | Dell Axim x51v and Sync Center Problem Hello, I am having a problem with the Sync Center and my Dell Axim x51v. It is set up in the Sync Center but when I connect the device to my computer, it still shows that the pda is disconnected and will not sync. I tried turning on the pda while in the cradle and running ActiveSync from the pda and it just says that it is connecting but does not do anything. The only solution that worked in the past is to download the sync center again and set up a new partnership. I can't do that every time I need to sync my pda. Any suggestions?? |
| Dell Axim X51v won't sync? | Vista General | |||
| Vista home sync center just stopped working with DELL Axim | Vista General | |||
| Dell Axim X51v has stopped syncing with WMDC 6.1 running on Vista Home Premium | Vista General | |||
| Axim X51v - Outlook 2003/Activsync Compatible with Vista? | Vista hardware & devices | |||
| Dell Axim X51v | Vista hardware & devices | |||
