Vista - Weird Problem
Old 05-20-2008   #1 (permalink)
Thomas
Weird Problem
Today I installed a program that will let you record any sound coming from
your speakers. It's a paid program and it's a reputable program but I
noticed something after the reboot. Im not sure it's related or not. When
I even move my cursor over a icon on my desktop it gives that windows
sounds, like a critical beep. When I click on a topic here in the newsgroup
to read, same thing. Clicking on contrl panel incons or any incons up
there, same noise. Its annoying. What happened? Any help would be
appreciated. Thanks.
Old 05-20-2008   #2 (permalink)
Rick Rogers
Re: Weird Problem
Something altered the associated sounds. Go to the Control Panel/Sound, and
on the sounds (third) tab, check the defaults.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Thomas" <forgetit@xxxxxx> wrote in message
news:X2KYj.9346$nl7.2765@xxxxxx
> When I even move my cursor over a icon on my desktop it gives that windows
> newsgroup to read, same thing. Clicking on contrl panel incons or any
> incons up there, same noise. Its annoying. What happened? Any help would
> be appreciated. Thanks.
Old 05-20-2008   #3 (permalink)
Thomas
Re: Weird Problem
"Rick Rogers" <rick@xxxxxx> wrote in message
news:u3a7xEuuIHA.5876@xxxxxx
Quote:
> Hi,
> and on the sounds (third) tab, check the defaults.
> Best of Luck,
>> from your speakers. It's a paid program and it's a reputable program but
>> I noticed something after the reboot. Im not sure it's related or not.
>> windows sounds, like a critical beep. When I click on a topic here in
>> the newsgroup to read, same thing. Clicking on contrl panel incons or
>> any incons up there, same noise. Its annoying. What happened? Any help
>> would be appreciated. Thanks.
Thanks, that fixed it. It showed my windows sound scheme as being altered.
Thanks for the help.
Old 05-21-2008   #4 (permalink)
Denny
Re: Weird Problem
> but I noticed something after the reboot. Im not sure it's related or
> not. When I even move my cursor over a icon on my desktop it gives that
What was the program, out of interest?
Old 05-21-2008   #5 (permalink)
Thomas
Re: Weird Problem
"Denny" <dlane@xxxxxx> wrote in message
news:g10dh3$73h$5@xxxxxx
The total program was total recorder.
Old 05-22-2008   #6 (permalink)
Denny
Re: Weird Problem
Thanks, I'll give it a go.
This was (another one of) those rudimentary things that I could do with
Win95/98/XP automatically using no third party software but can't do
with Vista.
Weird - Very weird annoying problem General Discussion
Weird ICS problem Vista networking & sharing
weird problem Vista mail
weird problem Vista General
weird problem Vista performance & maintenance
