Vista - How to "hover to click"
Old 05-22-2008   #1 (permalink)
Ike
In W98 and XP, I could click an icon or a menu list item
by hovering over it for some adjustable period (500ms
was the setting I used).
Is there a way to achieve this in Vista?
Thanks.
Old 05-22-2008   #2 (permalink)
Andrew Murray
Re: How to "hover to click"
I'd guess that in XP and W98 it would either have been under Mouse or
Accessibility settings, but I've just been into those areas in my Vista
system and can't seem to find any similar function.
There is a function, under my mouse settings (for my Microsoft Mouse
Wireless Optical at least) called "ClickLock" which lets you highlight or
drag without holding down the button.
To set, briefly hold down the primary (most cases, left) button. To
release, click the button again.
Not exactly what you need, but I can't see any other option.
"Ike" <binarydotike@xxxxxx> wrote in message
news:g142br$o63$1@xxxxxx
Quote:
> In W98 and XP, I could click an icon or a menu list item by hovering over
> it for some adjustable period (500ms was the setting I used).
> Thanks.
Old 05-23-2008   #3 (permalink)
Quote  Quote: Originally Posted by Ike View Post
Thanks.
Hi Ike,
In addition to Andrew's post about this tutorial below:
Mouse ClickLock
This tutorial may also be helpful on how to activate a window by hovering in it.
Mouse Hovering to Activate a Window
Old 05-23-2008   #4 (permalink)
Ike
Thanks.
What I once did was "click" by hovering over an icon or
a radio button, etc., for some definable period.
But I like the Hover-to-activate-window function under
Ease of Access.
Ike
"right click" and "open" on an icon does not start the program! Vista General
How can I make the right click "View source" open page in FrontPage? General Discussion
Vista Upgrade - Takes 30 Seconds to 5 minutes after mouse "click" Vista General
Right-click "Send to Mail Recipient" being overridden by MS Outloo Vista mail
Patch works with "right-click-apply", fails MsiApplyPatch, MsiExec Vista hardware & devices
