Vista Tutorial - Changing Vista Ultimate 64-bit to 32-bit
Old 05-22-2008   #1 (permalink)
Judith
Guest
I've touched on this previously a couple of months ago, but I then
incorporated a lot of questions at one time. HP offers a computer that has
everything I want except that the only Vista Ultimate offered is 64-bit. My
question is this: Since I want Ultimate, once I received it would I be able
to change the OS from Ultimate 64-bit to 32-bit? Based on my research about
software and external hardware I have, I should go with 32-bit, but for some
reason HP doesn't offer 32-bit Ultimate for this machine. They do offer
32-bit Vista Premium for the same PC, however.
Old 05-22-2008   #2 (permalink)
Tim Slattery
Guest
Re: Changing Vista Ultimate 64-bit to 32-bit
Only by blowing away the 64-bit system and installing the 32-bit
system from scratch. Of course, you'd have to get 32-bit drivers for
whatever on the computer needs them.
Tim Slattery
MS MVP(Shell/User)
Slattery_T@xxxxxx
http://members.cox.net/slatteryt
Old 05-22-2008   #3 (permalink)
Patrick Keenan
Guest
"Judith" <Judith@xxxxxx> wrote in message
news:74A7EA60-6B0C-44A6-8A71-F1D3C4DA5B26@xxxxxx
> has
> My
> able
> about
> some
Yes you can change, but you have to start from a bare drive, and if HP
doesn't supply it, you'll have to buy your own non-upgrade copy of Vista
Ultimate.
And you will need to be sure that the HP actually does have 32-bit drivers
for the board and attached hardware.
It's odd that they would do only 64-bit - you want to be sure in advance
that the reason for no 32-bit doesn't come as a nasty surprise. You might
call their sales line and see if there is a good reason.
HTH
-pk
Old 05-22-2008   #4 (permalink)
Jasper
Guest
> has
> My
> able
> about
> some
What would be the problem with 64 bit? It runs 32 bit apps without any
problems that I have run into.
Old 05-23-2008   #5 (permalink)
Judith
Guest
I appreciate all replies. Jasper, from what I have read the 64-bit OS might
not be compatible with my external hard drive, Sony external dvd burner and
my Plextor (for transferring vhs to dvd). I have searched for 64-bit drivers
for these on the various websites. To be honest, I'm not really concerned at
the present time as I will be keeping my WinXP MCE computer that is running
very well. But, there will come a time when the desktop will wear out and
the Vista computer might become my main computer. So, I want cutting edge
'everything' and still be able to use the equipment I listed above. Don't
really need the Vista computer--just want it. Most articles I read suggest
to stick with 32-bit. I'm just trying to be careful and as well informed as
can I can be on this subject. It was good to hear you had no problems with
the transition, though.
> > has
> > My
> > able
> > about
> > some
Old 05-23-2008   #6 (permalink)
Judith
Guest
thanks for the input, Patrick. Yes, it is strange about HP. I did email
them on the subject to see if I could have the 32-bit Ultimate since the
computer is customized. They just said, 'No.' When I get to that point that
I'm ready to take the plunge, I will call them.
> > has
> > My
> > able
> > about
> > some
> Ultimate.
> HTH
> -pk
Changing MUI on non-Vista Ultimate/Enterprise General Discussion
Only user account on Vista Ultimate says password is expired butaccess denied when changing. Vista account administration
Re: Changing my old Vi$ta Utlimate DVD to Vi$ta Ultimate SP1 DVD Vista General
Folder View keeps changing in Vista 64 Ultimate Vista General
32bit vista premium To anytime upgrade to ultimate. Changing to 64 Vista installation & setup
