Vista - Explorer - single click annoyance
Old 05-22-2008   #1 (permalink)
Fenster
In Explorer if you click a folder (in the left pane) it won't expand unless
you double click it or click the little arrow. This is different from XP
where clicking the folder would expand all the sub-folders. Even if you
turn on single click, it still requires you to double click folders (or
click the little arrow) in the left pane to expand them. Is there a way you
can revert to the XP behaviour?
Classic shell 'single click' problem in explorer.exe Vista General
Single click to open the tree in the Explorer Vista file management
Single Click Instead Of Double Click Vista General
Single Click? Vista General
hot to change mouse to single click instead of double click to ope Vista hardware & devices
