Vista - Event Viewer HELP!!
Old 05-23-2008   #1 (permalink)
vista home premium 32bit
Event Viewer HELP!!
Can anyone tell me wot this means? its happened 734 times in the last 24hrs!
Error- source nvstor32-ID 5-Task None? I only got me PC 3 months ago and thers thousands of events with errors and criticals!! wot do i do? Im new 2 all this so if anyone can help wil be gratefull! THANX
Old 05-25-2008   #2 (permalink)
LesleyO
Re: Event Viewer HELP!!
You seem to have posted this identical request in numerous places. Should we
take you seriously?
LesleyO
"macfin" <guest@xxxxxx-email.com> wrote in message
news:2373631f4e36faa5f97d68bdc9b23c4b@xxxxxx-gateway.com...
> last 24hrs!
> macfin
Old 05-26-2008   #3 (permalink)
TO LeselyO!! If i didnt need help I wouldnt bother asking!! THANX 4 ur HELP!?
Old 05-26-2008   #4 (permalink)
LesleyO
news:571f3f2138d7f1f244bbeca909c5e03f@xxxxxx-gateway.com...
> HELP!?
> macfin
Would if I could, but when someone posts the identical item to numerous
places (easy to find using Google), it looks suspicious. Perhaps that's why
you aren't getting assistance. I'm citing your original post again, here,
(below) in case others missed it. Perhaps they can help you.
LesleyO
___________________________
mad: Can anyone tell me wot this means? its happened 734 times in the
last 24hrs!
macfin
HELP need to solve this problem asap - Unable to start event viewer/event log service Software
Event Viewer Vista General
iaStor event in event viewer General Discussion
event viewer Vista performance & maintenance
BUG: a lot of errors "Event ID 6003 winlogon" in Event Viewer Vista General
