Vista - 0xc00000e9 help!!!
Old 05-23-2008   #1 (permalink)
norcofox
0xc00000e9 help!!!
Okay so about a week ago my laptop was acting strange so I restart it
and it doesn't want to start up and it just keeps trying to repair the
startup. This then stopped, for the next couple of days all it was
doing was going past the BIOS then a black screen with a blinking
cursor would appear and it would never boot. My brother bought the
recovery Cd for my Asus notebook, Im pretty much sure that it came with
Vista preinstalled on it so I dont have a vista CD, I tried the recovery
Cd. Now everytime i restart it it gives me options for safe mode etc I
have picked them all and it loads fr a bit then the screen goes to a
page with text saying reinstall windows and the registry is corrupt.
File: \windows\system32\config\system
Status: 0xc00000e9
Info: Windows failed to load because the system registry file is
missing, or corrupt.
Now I cant get into any of the safe modes at all and I dont have a
vista CD as it was preinstalled.
Help please?
I have a Asus notebook ( dunno what series)
1.73 ghz
2gig RAM
windows vista home premuim (i think)
I only have the recovery CD and another Cd that has drivers on it.
norcofox
norcofox's Profile: http://forums.techarena.in/member.php?userid=50226
View this thread: http://forums.techarena.in/showthread.php?t=974273
Old 05-23-2008   #2 (permalink)
Mick Murphy
RE: 0xc00000e9 help!!!
If you have DATA that has to be saved, take it to a Computer Technician, and
ask him to recover it using Knoppix live CD.
Then set your BIOS to boot from the DVD/CD drive 1st, insert the Asus
recovery disk, reboot, reinstall vista so your computer is back to factory
standards.
Also, reinstall the motherboard Drivers disk that came with it.
Mick Murphy - Qld - Australia
> Status: 0xc00000e9
> Help please?
> 1.73 ghz
> 2gig RAM
> norcofox
Old 05-24-2008   #3 (permalink)
norcofox
Re: 0xc00000e9 help!!!
I've done the recovery like 3 times, after each succesful recovery i
restart computer and it comes up with a similar error, there is 3
options.
Recover windows to whole of HD
Recover windows to 2 partitions
Recover windows to 1 partition
I dont care about my data I just want it back to normal
norcofox
Need help.. Quick! Status: 0xc00000e9 Vista General
ndis.sys error 0xc00000e9 Network & Sharing
Vista Error 0xc00000e9 Vista installation & setup
