| | Vista VPN Default gateway problem Hello everyone in windows XP i was UNcheck the default gateway for the vpn connection i create , so i can access the remote network without to have the destination gateway as my internet gateway when i do uncheck the same box in windows vista vpn connection, it come back to checked by default when connected?? i installed SP1 for vista, is there any solution may help ?? thank you. Ahmad Sabry |
| 0.0.0.0 default gateway problem | Vista General | |||
| Default gateway problem | Vista networking & sharing | |||
| Vista sleep and Default Gateway issue - KB933872 | Vista General | |||
| Problem to get default gateway in dhcp | Vista networking & sharing | |||
| Vista will not use manual default gateway | Vista networking & sharing | |||
