Vista Tutorial - re-installed Ultimate -- remote control wont work anymore..
Old 05-24-2008   #1 (permalink)
maya
Guest
hi,
I have this remote control, http://www.amazon.com/Windows-Vista-.../dp/B000ST7QPA
I just re-installed VIsta Ultimate, and now this remote control is not
working anymore.. it was working fine before I did the re-install..
it comes w/no driver, so short of disconnecting and connecting the
transmitter again to a USB port not sure what more I can do.. it used
to work fine not just with Windows Media Center but also with Rhapsody
and other stuff, now it does not work at all... I just put new
batteries in it... when I press a button on the remote the green
light on the remote goes on and the red light on the transmitter also
goes on.. so it's definitely not a battery problem..
(I know there's another, more specialized ng for this question in
microsoft.public.windows.vista hierarchy, but I'm posting thru google
now and can't find that group (posting thru google for now b/c also
have not been able to retrieve all prefs/info (i.e., passwords) for my
news client (Thunderbird..) )
thank you very much..
Old 05-24-2008   #2 (permalink)
Mark L. Ferguson
Guest
Re: re-installed Ultimate -- remote control wont work anymore..
Go to Start/Run, and type DEVMGMT.MSC , highlight the USB Root Hub
device(s), Action menu, "Uninstall", (do Not put a check in 'delete driver')
then Action menu, "scan for hardware changes", to find the device drivers
again automatically.
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"maya" <maya778899@xxxxxx> wrote in message
news:358580af-670a-4a35-a91b-0c139b279051@xxxxxx
Quote:
> hi,
Old 05-24-2008   #3 (permalink)
maya
Guest
thank you very much.. there are LOTS of "USB Root Hub" entries.. pls
see screenshot here,
http://www.mayacove.com/misc/ss_usb.gif.. which one? they're all
named the same, this can be confusing..
thank you very much for your help..
On May 24, 1:55 pm, "Mark L. Ferguson"
> interface.http://www.microsoft.com/wn3/locales...m#RateAPostAsA...
> Mark L. Ferguson
> "maya" <maya778...@xxxxxx> wrote in message
Quote:
> > hi,
> >http://www.amazon.com/Windows-Vista-...iver/dp/B000ST...
Old 05-24-2008   #4 (permalink)
Mark L. Ferguson
Guest
It won't hurt to try them all. Windows will replace the driver automatically
when you scan for changes.
interface.
Mark L. Ferguson
news:76efd59f-1d63-440b-ad67-38b2b67b372e@xxxxxx
>> driver')
>> Mark L. Ferguson
Quote:
>> > hi,
Old 05-24-2008   #5 (permalink)
maya
Guest
ok, so tried the first one.. took for ever, got stuck...both "cancel"
and "ok" buttons were ignored.. had to kill it from Task Mgr.. then
I tried another, same thing happened.... ah yes.. VISTA... thank
you very much...
On May 24, 2:51 pm, "Mark L. Ferguson"
> Mark L. Ferguson
> >> driver')
> >> Mark L. Ferguson
Quote:
Quote:
Quote:
Quote:
> >> > hi,
Old 05-24-2008   #6 (permalink)
maya
Guest
Re: re-installed Ultimate -- remote control wont work anymore..SOLVED
called my OEM (they were open today for tech support, believe it or
not....
what it was is I had to do what you said not on USB Root Hub but
another item under another list.... it works now...
> you very much...
> > Mark L. Ferguson
> > >> driver')
> > >> Mark L. Ferguson
Quote:
Quote:
Quote:
Quote:
> > >> > hi,
hot keys wont work on at catalyst control center Graphic cards
Installed Microphone wont work Vista General
where are vista pre-installed remote control drivers+registry entr Vista file management
vista installed games wont work Vista Games
Vista Ultimate - wont boot anymore Vista performance & maintenance
