| Vista Home Basic 32bit | Character problems in Vista Home Basic 32bit Hi there, I live in Japan, and I bought my laptop here. Thanks to this, I have a Japanese version of Windows Vista, which didn't really bother me so far, but now it has caused me a serious problem. I have a Fujitsu laptop, with an Intel Mobile 945GM Express Chipset. I would love to change some of my settings, due to recent software-crashes, for example the anisotrpoic filter. I open the interface of the driver, but on the buttons, and in the lists, I only see question marks. This happened many times before as well, but only at applications were I knew what to select anyways. I believe it will be a problem later on as well, so I would like to know why it is like this, and how I could get rid of this error. Even my friends who have Japanese Vista installed on their laptops, have no such problems with any sort of softwares... So I wonder what could be wrong. I appreciate any help I could get, thanks in advance! |
| | Re: Character problems in Vista Home Basic 32bit > Hi there, Quote: > > I live in Japan, and I bought my laptop here. Thanks to this, I have a > Japanese version of Windows Vista, which didn't really bother me so > far, but now it has caused me a serious problem. > > I have a Fujitsu laptop, with an Intel Mobile 945GM Express Chipset. I > would love to change some of my settings, due to recent > software-crashes, for example the anisotrpoic filter. > > I open the interface of the driver, but on the buttons, and in the > lists, I only see question marks. This happened many times before as > well, but only at applications were I knew what to select anyways. > > I believe it will be a problem later on as well, so I would like to > know why it is like this, and how I could get rid of this error. > > Even my friends who have Japanese Vista installed on their laptops, > have no such problems with any sort of softwares... So I wonder what > could be wrong. > > I appreciate any help I could get, thanks in advance! > problems (select your language version if you can). You can also check if Aero is causing this problem by turning it off change theme to windows classic (Display Properties). |
| | Re: Character problems in Vista Home Basic 32bit Question marks replacing UI strings typically indicates a Unicode -> ANSI transform failure. Is all of the software and drivers in either English or Japanese? Or is some of the software also in a third language? Seeing as how this is a Japanese laptop with Japanese Windows Vista, I'm guessing that the system locale (default ANSI code page) is set to Japanese (Japan). This should be fine for any ANSI-based component that contains UI strings in either English or Japanese. But if the system code page has been changed to something other than Japanese, and is an ANSI-based component with UI in a third language, the strings will not display properly. You can confirm the current system code page (aka 'Language for non-Unicode programs') by launching 'Regional and Language Options' from Control Panel. This setting can be checked on the Administrative tab. Best of luck, Garrett McGowan [MSFT] This posting is provided "AS IS" with no warranties, and confers no rights. Use of included script samples are subject to the terms specified at http://www.microsoft.com/info/cpyright.htm "mirek" <m.gon@xxxxxx> wrote in message news:a88c5df29eb28ca9dce6d7ef39a@xxxxxx Quote: Quote: >> Hi there, >> >> I live in Japan, and I bought my laptop here. Thanks to this, I have a >> Japanese version of Windows Vista, which didn't really bother me so >> far, but now it has caused me a serious problem. >> >> I have a Fujitsu laptop, with an Intel Mobile 945GM Express Chipset. I >> would love to change some of my settings, due to recent >> software-crashes, for example the anisotrpoic filter. >> >> I open the interface of the driver, but on the buttons, and in the >> lists, I only see question marks. This happened many times before as >> well, but only at applications were I knew what to select anyways. >> >> I believe it will be a problem later on as well, so I would like to >> know why it is like this, and how I could get rid of this error. >> >> Even my friends who have Japanese Vista installed on their laptops, >> have no such problems with any sort of softwares... So I wonder what >> could be wrong. >> >> I appreciate any help I could get, thanks in advance! >> > Try first install latest graphic drivers form intel.com it might fix your > problems (select your language version if you can). > You can also check if Aero is causing this problem by turning it off > change theme to windows classic (Display Properties). > |
| VISTA HOME BASIC 32BIT - WLAN - share printer or files, can I ? | Network & Sharing | |||
| skype runs ok in my VISTA HOME BASIC 32BIT, but icon/shortcut of skype in desktop, do | General Discussion | |||
| HELP... GTA 4 on windows vista home basic 32bit?? | Gaming | |||
| Home Network Problem on Vista Home Basic 32bit. | Network & Sharing | |||
| Vista Home Media 32bit problems | Media Center | |||
