Battery meter
  1. #1
    Battery Meter Guest
    Battery meter
    My battery meter stopped showing up on the toolbar. When i go into the
    taskbar properties and when i go into the notifications tab the power option
    is unavailable.
  2. #2
    Brian the King's Avatar
    Windows Vista Home Premium x64 SP2
    Local Time: 02:07 AM
    usa
    Re: Battery meter
    Hopefully someone will be of more help than I, but I did find a temporary fix for you;
    For many people with this problem, simply logging out and then back in will restore the battery meter, at least for a while.
  3. #3
    Ramesh, MS-MVP Guest
    Re: Battery meter
    See also:
    System icons may not appear in the notification area on a Windows Vista-based computer until you restart the computer:
    http://support.microsoft.com/kb/945011
    Regards,
    Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
    The Winhelponline Blog: http://www.winhelponline.com/blog
    Windows® Troubleshooting: http://www.winhelponline.com
    "Battery Meter" <Battery Meter@xxxxxx> wrote in message news:07332516-E116-4E96-842D-442A134A75A2@xxxxxx
    is unavailable.
Battery meter problems?
Battery Meter on task bar does not show Bob from down under Vista General 14 03 Nov 2009
Battery meter nhall2006 General Discussion 1 21 Apr 2009
Battery Strength Meter Rick Rockett Vista installation & setup 5 12 Sep 2007
Battery Meter CJP89 Vista hardware & devices 2 23 Aug 2007
Battery meter Carrie Vista General 1 25 Jun 2007
