1.    27 May 2008 #1
    KerriH Guest
    Deleting does not send items to Recycle Bin
    I have Windows Vista. Whenever I delete something, whether by just selecting
    it and pressing the delete key, selecting it and right-clicking and selecting
    Delete, or by dragging an item to the Recycle Bin, it asks me if I want to
    permanently delete the item. I usually say no because I don't want to. I want
    it to go to the Recycle Bin. But there are no options to send it there. I
    created a couple test files so that I could see what happens if I say Yes,
    and sure enough they do not go to the Recycle Bin, they are permanently
    deleted.
    I DO NOT have the setting to delete without sending something to the Recycle
    Bin checked. I have made sure of this numerous times.
    Anyone else experience this?
  2.    28 May 2008 #2
    Fallstar Guest
    RE: Deleting does not send items to Recycle Bin
    Is this setting found in the Recycle Bin Properties? If it's not,
    right-click the recycle bin and select Properties, then make sure "Do not
    move files to the Recycle Bin. Remove files immediately when deleted." is not
    selected...and also (above that) check the maximum size (MB) of the bin. Hope
    that helps...
  3.    28 May 2008 #3
    Rick Rogers Guest
    Re: Deleting does not send items to Recycle Bin
    Try first enabling that option on the Recycle Bin, then reboot and disable
    it.
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Windows help - www.rickrogers.org
    My thoughts http://rick-mvp.blogspot.com
    "KerriH" <KerriH@xxxxxx> wrote in message
    news:52E80958-D288-46AA-911D-E921FE310E61@xxxxxx
    >selecting
    > selecting
    > want
    > deleted.
    > Recycle
  4.    28 May 2008 #4
    flipper Guest
    i read the two replies you got below..... but have a question;
    why are you so paranoid about the file(s) merely sitting in r/bin? if you are worried about
    deleting something that you are not quite sure of 'yet', why not just make a folder on your d/top
    and call it 'ready for delete'. ? then you can deal with them a week later or whenever you are
    finally comfy blowin' them away. (you do know that the files will still remain on your hdd, dont
    you? personally, i have a tendency to be bluddy sure when i delete something, and when i do,
    i dont use windows r/bin, i use a 'shredder program' cos i know i want the files more than
    removed/deleted etc)
  5.    28 May 2008 #5
    KerriH Guest
    Rick,
    Thanks so much for your reply! This worked perfectly!
    Kerri
    "Rick Rogers" wrote:
    > Hi,
    > it.
    > Best of Luck,
    > >selecting
    > > selecting
    > > want
    > > deleted.
    > > Recycle
why can I not see items that have been placed in recycle bin
Hi I have moved a number of files to the recycle bin and I now cannot find them. the cash is set to 949GB has anyone any idea where it has gon to and...
Vista General
Recycle bin (window showing recycling items) on deleting an item
Hi everyone, When I delete items a window pops up saying Recycling (however many) item's and stays on the screen for a few seconds, sometimes for...
Vista performance & maintenance
recycle bin not showing all items
Hiya, I deleted something and could not find it in the recycle bin, and it shows 3 items in there, but when I empty the recycle bin, it said 6...
General Discussion
Deleted items do not show in recycle bin
I have just bought a new pc with Vista Home Premium x64. Problem is that the recycle bin won't show deleted items. The bin just looks empty. If I...
General Discussion
Recycle Bin - Deleted Items
I am unable to empty my deleted Items file. I get a message to say there is an error! Am using the select all and then Delete with no success
Vista file management
Problem deleting to recycle bin-Help!
When I try to send items to recycle bin for instance favorites-it gets hung up with the box saying deleting and I have to control alt delete to end...
Vista General
Recycle bin: HELP! Is there a temporary file for deleted items???
Marjorie here. Somebody please help me. I spent an hour or more today getting footage that can't be replicated. I copied all the image and video...
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
