Vista Tutorial - Wireless Vista problems after updating
Old 05-29-2008   #1 (permalink)
Bill
Guest
I am using a seimens 567 router that has wireless built in since about 6
months ago. I was using a linxsys router prior to that. I have been using
wireless since Mar 2007. about 2 months ago after upgrading vistais when
problem began.
The problem: I lose internet access after I turn my laptop off. It works
fine if I reboot the router before I want to use the internet again. The
router remembers the computers that were logged in the last time, even if
they are turned off, but no ip address.
Both the computer vendor, Acer, and microsoft want money to help you with
the problem.
I'm told it is solveable by fixing registry, but can't get the solution.
I believe it is a Microsoft problem since it worked fine before I upgraded
my Vista SW. My sons Laptop XP system has no problems on this network.
Acer Aspire 3680 laptop Seimens 567 modem DSL Vista Home Basic
Bill
Old 05-29-2008   #2 (permalink)
Mick Murphy
Guest
RE: Wireless Vista problems after updating
Check the router's manufacturer's website to see if there is updated vista
compatible firmware available for the router.
Mick Murphy - Qld - Australia
"Bill" wrote:
Quote:
> Hi,
> problem began.
> the problem.
> Bill
Some problems after updating... Vista General
Updating problems Vista x64: SP2 build 6002 Windows Updates
Vista updating problems Vista installation & setup
Windows Vista Ultimate Activating problems after updating to SP1 Vista General
Problems with Updating in Vista Vista General
