Vista Tutorial - No Bluetooth in Control Panel
Old 05-29-2008   #1 (permalink)
MintyFreak
Guest
I'm using a LAPTOP which has the bluetooth on/off button right next to the
wireless button (both built in)
I CANNOT find the Bluetooth option in the Control Panel.
I remember I've seen it before, but I dont know what happened to it.
Anyone know how to get it back?
Old 05-29-2008   #2 (permalink)
Mark L. Ferguson
Guest
Re: No Bluetooth in Control Panel
Go to HKLM\SYSTEM\CurrentControlSet\Control\Class\ in RegEdit. Delete the
following key: {e0cbf06c-cd8b-4647-bb8a-263b43f0f974}. Open Device Manager.
(run devmgmt.msc) Remove the Bluetooth radio listed here. Click Action,
click Scan for hardware changes. This should re-enumerate the Bluetooth
adapter..
click the Ratings button. Voting helps the web interface.
http://www.microsoft.com/wn3/locales...help_en-us.htm see ''rate a post''
Mark L. Ferguson
"MintyFreak" <MintyFreak@xxxxxx> wrote in message
news:53DDE92F-AEEB-453C-8068-21EB579BBD86@xxxxxx
Old 05-30-2008   #3 (permalink)
MintyFreak
Guest
Where do I find RegEdit?
& thank you
> adapter..
> Mark L. Ferguson
Old 05-30-2008   #4 (permalink)
MintyFreak
Guest
I've found RegEdit however I cannot find
"HKLM\SYSTEM\CurrentControlSet\Control\Class\"
The closest I get is "HKEY_Current_Config/System/CurrentControlSet/" and
then its either Control, Enum, or SERVICES
> adapter..
> Mark L. Ferguson
Bluetooth Device Control Panel Share Tab? Vista General
Bluetooth Device Control Panel Share Tab Vista networking & sharing
No bluetooth control panel Vista General
RC1: No bluetooth item in Control Panel. Vista hardware & devices
No Bluetooth Devices in Control Panel Vista hardware & devices
