| | Continuing problems with Network, Power & Volume icons Vista Ultimate SP1 (32-bit) on Dell Precision M6300 laptop. These 3 icons are a continual source of problems on this machine. When the machine boots, sometimes all 3 are missing, sometimes just the Power icon appears and sometimes all 3 actually appear but the Network icon has a red X on it even when there are no network connection issues. Just occasionally (say 1 in 5 boots) will all 3 icons be visible and in their correct states. I have tried the standard fix of applying or de-applying certain policies but none of those policies was ever in force to begin with. It goes without saying that when the icons are missing then they are grayed-out in the properties of the Start Menu. How do I get reliable behaviour from these icons? The machine is part of a domain which may be relevant in relation to Group Policies but I cannot see why they are there sometimes and then disappear after a reboot only to reappear on the next boot. -- And loving it, -Qu0ll (Rare, not extinct) _________________________________________________ Qu0llSixFour@xxxxxx [Replace the "SixFour" with numbers to email me] |
| | Re: Continuing problems with Network, Power & Volume icons "solon fox" <solonfox@xxxxxx> wrote in message news:5fb6350d-9bd6-4610-8f96- [...] Quote: > Go to Dell Support. Enter your service tag and check your drivers and > bios. Any other suggestions? This is driving me nuts. -- And loving it, -Qu0ll (Rare, not extinct) _________________________________________________ Qu0llSixFour@xxxxxx [Replace the "SixFour" with numbers to email me] |
| | Re: Continuing problems with Network, Power & Volume icons On May 30, 4:24*pm, "Qu0ll" <Qu0llSixF...@xxxxxx> wrote: Quote: > "solon fox" <solon...@xxxxxx> wrote in message > > news:5fb6350d-9bd6-4610-8f96- > > [...] > Quote: > > Go to Dell Support. Enter your service tag and check your drivers and > > bios. > All drivers are up to date, as is the BIOS. > > Any other suggestions? *This is driving me nuts. > > -- > And loving it, > > -Qu0ll (Rare, not extinct) > _________________________________________________ > Qu0llSixF...@xxxxxx > [Replace the "SixFour" with numbers to email me] utility might be acting up. If QuickSet is installed, it isn't easily removed; but, Dell provides a QuickSet removal utility at the same place that you checked their drivers. I removed the QuickSet from my laptops for other reasons and it is a shot in the dark to blame it for your problem, but I don't have the problem. It seems pretty rare indeed. -solon fox |
| | Re: Continuing problems with Network, Power & Volume icons "solon fox" <solonfox@xxxxxx> wrote in message news:7eac7ce0-b5cf-4748-83f1-c31570e8e011@xxxxxx [...] Quote: > Do you use a docking station? I'm wondering if the Dell QuickSet > utility might be acting up. If QuickSet is installed, it isn't easily > removed; but, Dell provides a QuickSet removal utility at the same > place that you checked their drivers. > > I removed the QuickSet from my laptops for other reasons and it is a > shot in the dark to blame it for your problem, but I don't have the > problem. It seems pretty rare indeed. noticed that QuickSet sometimes puts an icon on the task bar (NB. not the system tray but the task bar) with no title and with no menu when I right-click on it. So perhaps it is acting up as you say. I will see if I can remove it and then see if that resolves the issues. What do I lose by removing QuickSet anyway? Thanks for your input. -- And loving it, -Qu0ll (Rare, not extinct) _________________________________________________ Qu0llSixFour@xxxxxx [Replace the "SixFour" with numbers to email me] |
| | Re: Continuing problems with Network, Power & Volume icons On May 30, 9:08*pm, "Qu0ll" <Qu0llSixF...@xxxxxx> wrote: Quote: > "solon fox" <solon...@xxxxxx> wrote in message > > news:7eac7ce0-b5cf-4748-83f1-c31570e8e011@xxxxxx > > [...] > Quote: > > Do you use a docking station? I'm wondering if the Dell QuickSet > > utility might be acting up. If QuickSet is installed, it isn't easily > > removed; but, Dell provides a QuickSet removal utility at the same > > place that you checked their drivers. Quote: > > I removed the QuickSet from my laptops for other reasons and it is a > > shot in the dark to blame it for your problem, but I don't have the > > problem. It seems pretty rare indeed. > You might be on to something here. *I am using a docking station and I have > noticed that QuickSet sometimes puts an icon on the task bar (NB. not the > system tray but the task bar) with no title and with no menu when I > right-click on it. *So perhaps it is acting up as you say. > > I will see if I can remove it and then see if that resolves the issues. > What do I lose by removing QuickSet anyway? > > Thanks for your input. > > -- > And loving it, > > -Qu0ll (Rare, not extinct) > _________________________________________________ > Qu0llSixF...@xxxxxx > [Replace the "SixFour" with numbers to email me] In theory, it automatically detects network connections and changes your default printer, proxy settings, network drives, etc depending on whether you are docked, undocked, on your home network, work network or other public network. Initially, it looked really promising, but was just too flaky and I removed it because I got tired of trying to tweak it. I'm not saying that losing it will fix the problem, but it is reminiscent of the quirky troubles I had with it. I know you mentioned group policies and domains and such and those are things that could certainly interfere with QuickSet's attempts to identify your location and settings -- I think maybe there are just too many variables for this fantasy app to keep up with. Plus, ever other day Microsoft update is changing some obscure key that the utility depends on. You probably won't miss it because you have to configure it and then train it for it to be of any use at all. -solon fox |
| | #6 (permalink) |
| | Re: Continuing problems with Network, Power & Volume icons On May 31, 12:00*am, solon fox <solon...@xxxxxx> wrote: Quote: > On May 30, 9:08*pm, "Qu0ll" <Qu0llSixF...@xxxxxx> wrote: > > > > > Quote: > > "solon fox" <solon...@xxxxxx> wrote in message Quote: > >news:7eac7ce0-b5cf-4748-83f1-c31570e8e011@xxxxxx Quote: > > [...] Quote: Quote: > > > Do you use a docking station? I'm wondering if the Dell QuickSet > > > utility might be acting up. If QuickSet is installed, it isn't easily > > > removed; but, Dell provides a QuickSet removal utility at the same > > > place that you checked their drivers. Quote: Quote: > > > I removed the QuickSet from my laptops for other reasons and it is a > > > shot in the dark to blame it for your problem, but I don't have the > > > problem. It seems pretty rare indeed. Quote: > > You might be on to something here. *I am using a docking station and Ihave > > noticed that QuickSet sometimes puts an icon on the task bar (NB. not the > > system tray but the task bar) with no title and with no menu when I > > right-click on it. *So perhaps it is acting up as you say. Quote: > > I will see if I can remove it and then see if that resolves the issues. > > What do I lose by removing QuickSet anyway? Quote: > > Thanks for your input. Quote: > > -- > > And loving it, Quote: > > -Qu0ll (Rare, not extinct) > > _________________________________________________ > > Qu0llSixF...@xxxxxx > > [Replace the "SixFour" with numbers to email me] > QuickSet would be really cool, if only it worked properly... > > In theory, it automatically detects network connections and changes > your default printer, proxy settings, network drives, etc depending on > whether you are docked, undocked, on your home network, work network > or other public network. Initially, it looked really promising, but > was just too flaky and I removed it because I got tired of trying to > tweak it. > > I'm not saying that losing it will fix the problem, but it is > reminiscent of the quirky troubles I had with it. I know you mentioned > group policies and domains and such and those are things that could > certainly interfere with QuickSet's attempts to identify your location > and settings -- I think maybe there are just too many variables for > this fantasy app to keep up with. Plus, ever other day Microsoft > update is changing some obscure key that the utility depends on. > > You probably won't miss it because you have to configure it and then > train it for it to be of any use at all. > > -solon fox- Hide quoted text - > > - Show quoted text - Area' and uncheck the box that says "Hide inactive icons." Leave it unchecked at least until you are satisfied that the problem has been resolved. Also, sometimes people get confused looking at the network icons. When docked, you may see a network icon with a red 'x' even when you know you are connected. It might be that it is the wireless icon. To fix this, hot undock (i.e. undock without shutting down), make sure that the wireless is enabled through Control Panel->Network and Internet- Quote: >Network and Sharing Center, on the left panel select 'Manage network Hot undock, make sure the wireless is enabled through 'Manage network connections'. Now, dock again. Wireless will be disabled. From now on, each time you undock wireless will be automatically enabled and more importantly, each time you dock the wireless will be automatically disabled. That way, you won't be looking at one dead network icon - the one with the red 'x' - and one live network icon when you are docked. You should now only see the active network icon when docked, assuming that you don't need the wireless network connection when docked. Bluetooth will still be available. -solon fox |
| | #7 (permalink) |
| | Re: Continuing problems with Network, Power & Volume icons "solon fox" <solonfox@xxxxxx> wrote in message news:6adea4e2-4a40-4a6c-a1e6-ad8da900a623@xxxxxx [...] Quote: Quote: >> QuickSet would be really cool, if only it worked properly... >> >> In theory, it automatically detects network connections and changes >> your default printer, proxy settings, network drives, etc depending on >> whether you are docked, undocked, on your home network, work network >> or other public network. Initially, it looked really promising, but >> was just too flaky and I removed it because I got tired of trying to >> tweak it. >> >> I'm not saying that losing it will fix the problem, but it is >> reminiscent of the quirky troubles I had with it. I know you mentioned >> group policies and domains and such and those are things that could >> certainly interfere with QuickSet's attempts to identify your location >> and settings -- I think maybe there are just too many variables for >> this fantasy app to keep up with. Plus, ever other day Microsoft >> update is changing some obscure key that the utility depends on. >> >> You probably won't miss it because you have to configure it and then >> train it for it to be of any use at all. >> >> -solon fox- Hide quoted text - >> >> - Show quoted text - > One more suggestion, do a properties on the task bar, 'Notification > Area' and uncheck the box that says "Hide inactive icons." Leave it > unchecked at least until you are satisfied that the problem has been > resolved. > > Also, sometimes people get confused looking at the network icons. When > docked, you may see a network icon with a red 'x' even when you know > you are connected. It might be that it is the wireless icon. To fix > this, hot undock (i.e. undock without shutting down), make sure that > the wireless is enabled through Control Panel->Network and Internet- Quote: >>Network and Sharing Center, on the left panel select 'Manage network > Hot undock, make sure the wireless is enabled through 'Manage network > connections'. Now, dock again. Wireless will be disabled. From now on, > each time you undock wireless will be automatically enabled and more > importantly, each time you dock the wireless will be automatically > disabled. That way, you won't be looking at one dead network icon - > the one with the red 'x' - and one live network icon when you are > docked. You should now only see the active network icon when docked, > assuming that you don't need the wireless network connection when > docked. Bluetooth will still be available. > > -solon fox network icon with the wireless one. But solon fox, I am considering this matter resolved in that I have rebooted about 5 times since my last post and all icons have appeared each time. Therefore, it indeed looks like QuickSet was the problem. I will contact Dell and see if they can suggest a solution. Thanks sincerely for the suggestion to remove QuickSet! -- And loving it, -Qu0ll (Rare, not extinct) _________________________________________________ Qu0llSixFour@xxxxxx [Replace the "SixFour" with numbers to email me] |
| Lost Volume, Network, Power icons from notification area | Vista General | |||
| Volume, network, and power icon missing from notificaion area | Vista performance & maintenance | |||
| Network, Volume and Power Greyed out on Notification Area Icons | Vista General | |||
| Volume, Network and Power Icons and Booting up with Vista | Vista General | |||
| Keep losing my volume & power icons | Vista General | |||
