Vista - Can I system restore beyond the given restore points?
Old 05-31-2008   #1 (permalink)
let-la
I have not been able to resolve my sound and messenger problems that occured
after an update. However, when I go to system restore, it only goes back 5
days and I need it to go back 6. Is there any way to restore to a point
previous to the points they offer? Thanks.
Old 05-31-2008   #2 (permalink)
Mike Hall - MVP
Re: Can I system restore beyond the given restore points?
"let-la" <letla@xxxxxx> wrote in message
news:A111FFDC-8AA9-4F0A-B681-254785DCF63A@xxxxxx
>occured
No. The data to do the system restore further back no longer exists..
Mike Hall - MVP
How to construct a good post..
http://dts-l.com/goodpost.htm
How to use the Microsoft Product Support Newsgroups..
http://support.microsoft.com/default...help&style=toc
Mike's Window - My Blog..
http://msmvps.com/blogs/mikehall/default.aspx
Old 05-31-2008   #3 (permalink)
Quote  Quote: Originally Posted by let-la View Post
Hi Let-La,
Be sure to check the box in step 3B shown in this tutorial for how to see the ones older than 5 days.
System Restore - How to
If you would like to increase the amount of storage space used for System Restore for restore points so you can have more to select from later, then this tutorial will show you how to.
System Restore - disk space
Old 05-31-2008   #4 (permalink)
Home premium 32 bit, SP1
Hello let-la,
Just in case you missed it :
(click the screen shot link )
ImageGrotto: Free Image and Screenshot Hosting
System Restore.... Restore Points Vista General
System Restore: do restore points persist after a restore? Vista General
System Restore Deleting Restore Points Automatically.... Vista General
System restore unable to restore points Vista General
system restore (automatic daily restore points) Vista General
