Vista - Start button -- start menu Problem
Old 06-01-2008   #1 (permalink)
Vista Home Premium 64-bit
Start button on Monitor #1-- Start Menu on Monitor #2
I use 2 identical monitors side by side with Vista Home Premium 64-bit, and use the classic Start Menu. Here's the problem:
Just recently, something odd has been happening: When I click the Start Button which is where it should be, that is on the left hand side of Monitor #1, the Classic Start Menu opens on Monitor #2... How can I get my Start Menu to display on the same monitor as the Start Button again?
NOTE: This problem does not happen if I use the Vista Start Menu, but as soon as I switch back to view the classic Start Menu, which I much prefer, it's displayed on the wrong monitor when I click the Start Button Orb.
Vladsky
Old 06-01-2008   #2 (permalink)
Re: Start button -- start menu Problem
Found my own solution...
Control Panel.... Tablet PC Settings.... Set myself as Left-Handed...
Voilą... the Start Menu Opens on Monitor #1, the same monitor where the Start Button is.
It might not be an elegant solution but it gets the job done!
Vladsky [...gives himself a pat on the back...good dog!]
Lock Button on Start Menu will not show Menu Vista General
Power button in the Start menu Vista General
Start menu button Vista General
Power button on Start Menu Vista General
Start Menu - Pictures Button does nothing Vista General
