possible to forward port on a wireless connection?
  1. #1
    mapleleaves Guest
    is it possible to forward a port on a wireless connection. i have a
    dlink dwl-g122. i need to forward a port so i can maximize my dl speeds
    on utorrent...
    if it is possible and explanation would be terrific!
    thanks in advance
    mapleleaves
    mapleleaves's Profile: http://forums.techarena.in/member.php?userid=50826
    View this thread: http://forums.techarena.in/showthread.php?t=979331
  2. #2
    Kerry Brown Guest
    Re: possible to forward port on a wireless connection?
    Yes. with most routers it's possible. It is done in the router's setup. How
    it's done is slightly different with different routers. You'd have to look
    in the manual for your router. You give the computer a static IP address
    then in the router setup you forward the port to that IP address.
    Kerry Brown
    MS-MVP - Windows Desktop Experience: Systems Administration
    http://www.vistahelp.ca/phpBB2/
    "mapleleaves" <mapleleaves.3ad13e@xxxxxx> wrote in message
    news:mapleleaves.3ad13e@xxxxxx
    > on utorrent...
    > thanks in advance
    > mapleleaves
  3. #3
    Rick Rogers Guest
    Sure it is possible. Port forwarding is done by the router, and it doesn't
    care if the connection is wired or wireless. You might want to set an
    assigned IP in the router for that wireless device rather than have it
    randomly assigned, or you would have to update the forwarding mechanism each
    time you connect.
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Windows help - www.rickrogers.org
    My thoughts http://rick-mvp.blogspot.com
    > on utorrent...
    > thanks in advance
    > mapleleaves
  4. #4
    Synapse Syndrome Guest
    > on utorrent...
    > thanks in advance
    uTorrent seems to support UPnP, from Googling. So the easiest option would
    be to enable it in uTorrent. Then the port forwarding will be done for you
    automatically.
    ss.
  5. #5
    Mr. Arnold Guest
    > on utorrent...
    There is a Support Knowledge Base at the manufacturer's website that will
    tell you how to set the router to do port forwarding. You might want to
    look-up how to use a static IP on the router that the computer will use too.
SBS 2008 Port Forward Question Richard K SBS Server 21 06 Sep 2009
www.microsoft.com is not set up to establish a connection on port fatherland Vista networking & sharing 0 04 Jun 2008
which computer to port forward to? todlarson Live Folder Share 3 18 Mar 2008
Messenger connection port Rikrdo Live Messenger 1 07 Dec 2007
how do i port forward martin dickinson Vista security 2 26 Nov 2007
