RAW hard drive
  1. #1
    J Lunis Guest
    RAW hard drive
    Recently bought a PC with Vista Home Premium. Have a lot of little
    questions I may post here if I can't find the answers online. But for
    now, my most significant problem.
    I have a USB HD that worked flawlessly under XP. But when I plugged it
    in to the4 new (Vista) PC it does not appear in Explorer and Disk
    Management shows it as 'RAW.' How do I get Vista to detect/read it?
  2. #2
    solon fox Guest
    Re: RAW hard drive
    On Jun 2, 8:05*am, J Lunis <jay.lu...@xxxxxx> wrote:
    > Recently bought a PC with Vista Home Premium. *Have a lot of little
    > questions I may post here if I can't find the answers online. *But for
    > I have a USB HD that worked flawlessly under XP. *But when I plugged it
    > Management shows it as 'RAW.' *How do I get Vista to detect/read it?
    See http://www.mscd.edu/~ittsdba/oradoc8...a73025/ch3.htm
    I'm not saying you should do this, but if it were my drive. I would
    transfer the data using the XP machine and then format the drive and
    return the data. If you want to just plug and play to different
    machines, format the drive as FAT32 (default) . Format it as NTFS if
    you want an added layer of authentication and password security.
    -solon fox
RAW hard drive problems?
Hard drive light constantly flashing ,reading hard drive during id Sid Vista hardware & devices 17 26 Mar 2009
Transfering from XP hard drive to vista Hard drive Gatorpit Vista General 0 11 Nov 2008
No online media available on new hard drive - old hard drive had l esher88 Vista music pictures video 0 12 May 2008
Crashed hard drive...copied hard drive but can't access User area chambersbobby Vista General 2 22 Apr 2008
Transferring files from Slave XP hard drive to new Vista Hard drive - primary Scootermc50@gmail.com Vista installation & setup 1 23 May 2007
