| | Problem with Complete PC Backup, not so complete The backup is not failing, it says it's complete, but the file that it creates is less than 70GB, and my drive is 225GB full out of 279GB. The machine is running Vista Ultimate and running Vista Media Center. 157GB of the files are recorded shows, my music and pictures. I'm expecting a file closer to 225GB, especially since media files don't compress well (if this program compresses). I find it awfully coincidental that 225 - 157 = 68, which is about the size of my backup file. The bigger problem is that I can't use the backup it creates. When I go to the restore operation, it finds the backup, I hit start and get back Restore Failed, element not found 0x80070490, which leads me to believe the backup is incomplete. |
| | Re: Problem with Complete PC Backup, not so complete On Tue, 3 Jun 2008 14:26:01 -0700, R5 <R5@xxxxxx> wrote: Quote: >The backup is not failing, it says it's complete, but the file that it >creates is less than 70GB, and my drive is 225GB full out of 279GB. The >machine is running Vista Ultimate and running Vista Media Center. 157GB of >the files are recorded shows, my music and pictures. I'm expecting a file >closer to 225GB, especially since media files don't compress well (if this >program compresses). > >I find it awfully coincidental that 225 - 157 = 68, which is about the size >of my backup file. > >The bigger problem is that I can't use the backup it creates. When I go to >the restore operation, it finds the backup, I hit start and get back Restore >Failed, element not found 0x80070490, which leads me to believe the backup is >incomplete. shipping. |
| | Re: Problem with Complete PC Backup, not so complete "R5" <R5@xxxxxx> wrote in message news:C0DDE582-8C07-431B-8C68-4E6E95D7657C@xxxxxx Quote: > The backup is not failing, it says it's complete, but the file that it > creates is less than 70GB, and my drive is 225GB full out of 279GB. The > machine is running Vista Ultimate and running Vista Media Center. 157GB > of > the files are recorded shows, my music and pictures. I'm expecting a file > closer to 225GB, especially since media files don't compress well (if this > program compresses). > > I find it awfully coincidental that 225 - 157 = 68, which is about the > size > of my backup file. > > The bigger problem is that I can't use the backup it creates. When I go > to > the restore operation, it finds the backup, I hit start and get back > Restore > Failed, element not found 0x80070490, which leads me to believe the backup > is > incomplete. There are reasons many people don't use the Windows backup utilities. Works for some people, not for others. I suggest an imaging program, and agree that Acronis TrueImage is a good bet, and inexpensive. HTH -pk |
| | Re: Problem with Complete PC Backup, not so complete Thanks for the replies, hopefully someone from Microsoft will actually respond to this, because this is pretty pathetic. The native backup that has come with Windows has always been dependable, now this stuff is failing, and reporting that it was successful. I have had good luck with this software on my other Vista machine, but it was only a 80gb drive. "Patrick Keenan" wrote: Quote: > "R5" <R5@xxxxxx> wrote in message > news:C0DDE582-8C07-431B-8C68-4E6E95D7657C@xxxxxx Quote: > > The backup is not failing, it says it's complete, but the file that it > > creates is less than 70GB, and my drive is 225GB full out of 279GB. The > > machine is running Vista Ultimate and running Vista Media Center. 157GB > > of > > the files are recorded shows, my music and pictures. I'm expecting a file > > closer to 225GB, especially since media files don't compress well (if this > > program compresses). > > > > I find it awfully coincidental that 225 - 157 = 68, which is about the > > size > > of my backup file. > > > > The bigger problem is that I can't use the backup it creates. When I go > > to > > the restore operation, it finds the backup, I hit start and get back > > Restore > > Failed, element not found 0x80070490, which leads me to believe the backup > > is > > incomplete. > Apparently the backup *is* failing. It's just misreporting the failure. > > There are reasons many people don't use the Windows backup utilities. Works > for some people, not for others. I suggest an imaging program, and agree > that Acronis TrueImage is a good bet, and inexpensive. > > HTH > -pk > > |
| | Re: Problem with Complete PC Backup, not so complete On Wed, 4 Jun 2008 07:50:00 -0700, R5 <R5@xxxxxx> wrote: Quote: >Thanks for the replies, hopefully someone from Microsoft will actually >respond to this, because this is pretty pathetic. rule, it is not frequented by MS people. Quote: > The native backup that has >come with Windows has always been dependable, now this stuff is failing, and >reporting that it was successful. > >I have had good luck with this software on my other Vista machine, but it >was only a 80gb drive. > >"Patrick Keenan" wrote: > Quote: >> "R5" <R5@xxxxxx> wrote in message >> news:C0DDE582-8C07-431B-8C68-4E6E95D7657C@xxxxxx Quote: >> > The backup is not failing, it says it's complete, but the file that it >> > creates is less than 70GB, and my drive is 225GB full out of 279GB. The >> > machine is running Vista Ultimate and running Vista Media Center. 157GB >> > of >> > the files are recorded shows, my music and pictures. I'm expecting a file >> > closer to 225GB, especially since media files don't compress well (if this >> > program compresses). >> > >> > I find it awfully coincidental that 225 - 157 = 68, which is about the >> > size >> > of my backup file. >> > >> > The bigger problem is that I can't use the backup it creates. When I go >> > to >> > the restore operation, it finds the backup, I hit start and get back >> > Restore >> > Failed, element not found 0x80070490, which leads me to believe the backup >> > is >> > incomplete. >> Apparently the backup *is* failing. It's just misreporting the failure. >> >> There are reasons many people don't use the Windows backup utilities. Works >> for some people, not for others. I suggest an imaging program, and agree >> that Acronis TrueImage is a good bet, and inexpensive. >> >> HTH >> -pk >> >> |
| | #6 (permalink) |
| Ultimate x64 | Re: Problem with Complete PC Backup, not so complete Nice, just buy another program? No, Microsoft should buy them and incorporate it for those of us who shelled out the money for the advanced versions (e.g. Ultimate). I guess I will just send in my receipt to Microsoft since this is advertised as one of the features and they are not addressing it. If they refuse then I guess it is time to start another class action lawsuit for ALL the aspects of Vista that STILL do not work, yet are still advertised as such. Glad I found the precedent here: Full text: Microsoft execs on Vista problems |
| Complete PC Backup Problem | Vista General | |||
| Complete PC Backup Problem | Vista performance & maintenance | |||
| Complete PC backup problem | Vista file management | |||
