Vista - battery model
Old 06-04-2008   #1 (permalink)
Sphinx
battery model
can anyone tell me where i can find out the battery model on my pc as i wish
to buy another as a spare ideally i would like to buy one that lasts longer
than 3 hours any suggestions on make and model. I currently have a Toshiba
satellite pro.
Old 06-04-2008   #2 (permalink)
Nonny
Re: battery model
On Wed, 4 Jun 2008 08:48:01 -0700, Sphinx
>satellite pro.
Go to the Toshiba site and look it up.
DUH.
Old 06-04-2008   #3 (permalink)
Tim Slattery
Re: battery model
>satellite pro.
The user's manual for your Toshiba Satellite is in a *.pdf file stored
on the machine someplace. When you brought the machine home, there was
a shortcut to it on the desktop. The information will be in there.
Of course, you can also pop the current battery out and see what model
number is printed on it. (Make sure the machine is shut down or
hibernated. Don't pop the battery while it's asleep!)
For a longer lasting battery, first look in the user's manual, they ma
very well have the information there. If not there, then try Toshiba's
web site. If still no joy, try Google.
Tim Slattery
MS MVP(Shell/User)
Slattery_T@xxxxxx
http://members.cox.net/slatteryt
Battery model Vista performance & maintenance
Wii input model? Vista General
Laptop battery issue ??battery calibration?? General Discussion
How does a computer know what model it is???? Vista installation & setup
