Vista - setting up cable TV: WMC can't detect cable signal
Old 06-07-2008   #1 (permalink)
maya
hi,
I'm trying to set up Windows Media Center for CABLE TV. have two
tuners installed, installed cable card from COMCAST, connected the
cable TV cable (the white cable fro cable TV), but no matter what I
do, WMC cannot detect the cable signal, what could this be? (even if
I take out the cable card and try to configure for just basic cable TV
it cannot detect any cable TV signal..) the cable guy was here over
an hour, we were not able to set it up.. now cable TV works fine
throughout my house, for TV in living room and in the two bedrooms,
but, even though we took the cable from the regular TV in my bedroom
and connected it to the back of the TV tuner in the computer, WMC was
not able to detect a cable TV signal....
was wondering if anybody has any suggestions..
thank you..
Old 06-07-2008   #2 (permalink)
Carey Frisch [MVP]
Re: setting up cable TV: WMC can't detect cable signal
Contact your service provider to pair your CableCARD with the Digital Cable Tuner-
this will activate both so you can receive digital cable content. You will be required to
provide the following information to your service provider:
1. CableCARD ID: This number will be reported in Windows Media Center on the Call your cable company page. (Example:
000-298-933-268-5)
2. Host ID: This number will be reported in Windows Media Center on the Call your cable company page. (Example: 029-000-000-104-7)
3. Data: This number will be reported in Windows Media Center on the Call your cable company page. (Example: 132-028-947-08)
4. UnitAddress: You'll find this number on the outside of your CableCARD device. (Example: 000-02989-33268-246)
5. CableCARD S/N: You'll find this number on the outside of your CableCARD device. (Example: NG3549TA0113)
Carey Frisch
Microsoft MVP
Windows Desktop Experience -
Windows Vista Enthusiast
"maya" <maya778899@xxxxxx> wrote in message news:bc574330-ef6a-4073-8016-07c5ef1c258e@xxxxxx
hi,
thank you..
Old 06-07-2008   #3 (permalink)
maya
this was all done.. the cable guy was on the phone w/cable co. for a
long time giving them all these numbers you mention, that were
displayed on WMC for the card.. this was just to activate the cable
card.. at the end WMC said "you're done".. this was just for the cable
card.. but later, for setting up the cable TV signal, we tried a no.
of times, WMC simply could not detect the signal.. I also had tech
support for my OEM on the phone, he even remote-connected to my
computer.. nothing we tried worked, WMC would simply not detect a
cable TV signal.. after the cable guy left I disconnected the cable
from the computer and connected it back to the TV, it worked fine.. I
simply have no idea why WMC is doing this... my OEM, fortunately,
they have GREAT tech support, and are continuing to trouble-shoot
issue for me...
thank you very much for yr response...
On Jun 7, 6:10 pm, "Carey Frisch [MVP]" <cnfri...@xxxxxx>
> 000-298-933-268-5)
> Carey Frisch
> Microsoft MVP
> "maya" <maya778...@xxxxxx> wrote in messagenews:bc574330-ef6a-4073-8016-07c5ef1c258e@xxxxxx
> hi,
> thank you..
Old 06-07-2008   #4 (permalink)
Charlie Tame
> issue for me...
>> 000-298-933-268-5)
>> Carey Frisch
>> Microsoft MVP
>> hi,
>> thank you..
How many TV connectors are on the card? Did you try any others or just
the one marked for cable? If not try the antenna connector.
You mention that you reconnected to the TV and it works, that's good but
if this is coming from the back of your cable TV box then instead try
the cable that comes out of the wall... hmm the situation I have is
Wall outlet to 3 way splitter splitter
One from splitter to input of cable box
one from splitter to tuner card
one from splitter to second tuner card
If your present connection goes from the "Out" side of the cable box to
the card then that may be the problem.
Note this is just maybe because I do not know Comcast stuff at all.
Old 06-07-2008   #5 (permalink)
Carey Frisch [MVP]
Error after you insert a CableCARD in Windows Vista: "No Signal"
http://support.microsoft.com/kb/927529/en-us
Carey Frisch
Microsoft MVP
"maya" <maya778899@xxxxxx> wrote in message news:bb27edf4-3ea1-458b-8ffb-1c3ec7f30823@xxxxxx
issue for me...
> 000-298-933-268-5)
> Carey Frisch
> Microsoft MVP
> hi,
> thank you..
Old 06-07-2008   #6 (permalink)
Charlie Tame
I think you have it, I misunderstood the situation having just been
helping someone with a TV card but FYI I think the same can happen with
tuner cards as I had something similar with mine. Trouble is I don't
know what fixed my problem, I think it was outdated OEM drivers, but the
message was much the same - no signal when I knew there was.
Old 06-07-2008   #7 (permalink)
maya
thank you for yr responses.. let me just clarify that this has
NOTHING to do w/the cable card.. the cable card from COMCAST is only
for DIGITAL cable.. as long as you have a cable tuner inside the
computer you can still get cable TV, it just wont be DIGITAL cable if
you don't have a card.. (this card is the equiv of a digital cable box
and, just like with a regular TV, if u dont have a digital cable box
you can still get basic cable..) but WMC wouldn't detect a cable TV
signal even after we took the card out and tried to set up for just
basic cable...
thanks again...
Old 06-07-2008   #8 (permalink)
Carey Frisch [MVP]
Feel free to open a support request directly with Microsoft:
https://support.microsoft.com/oas/de...6&gprid=436922
Carey Frisch
Microsoft MVP
"maya" <maya778899@xxxxxx> wrote in message news:d5a3e406-6934-4ddd-896e-abd2d09158b7@xxxxxx
basic cable...
thanks again...
Old 06-08-2008   #9 (permalink)
peggy
Maya,
You mention that you have two TV tuners. Have you tried removing one of the
TV tuners and installing just one without the cable card and then removing
that one and installing the other to determine if one of the tuners is bad?
Quote:
> hi,
> thank you..
Old 06-08-2008   #10 (permalink)
maya
yes, as a matter of fact, when we connected the cards one tuner always
showed a red light (each one has a green and a red light, one of them
always showed a red light) so we disabled that tuner and tried w/only
the one tuner that was showing a green light... but it still wouldn't
work....
On Jun 8, 11:03 am, "peggy" <nos...@xxxxxx> wrote:
Quote:
> Maya,
Quote:
> > hi,
Quote:
> > thank you..
Cannot connect to internet using Ethernet Cable but can connect with USB cable Network & Sharing
Cleaned computer now unable to detect cable Vista networking & sharing
WMC/TV Tuner and Digital Cable Box - Scrambled Signal Vista General
Vista Ultimate cannot detect direct cable connection Vista networking & sharing
Changing MCE tv-signal to cable Vista installation & setup
