| Guest | DVD Drive problem When I insert a CD or DVD into one of my two drives, it will play but I can't get it to eject. The physical drive button doesn't do it, and if I right click on the drive letter and try "eject" I get an error message. The only way is to physically insert something in the hole, or reboot. Any thoughts? |
| Guest | Re: DVD Drive problem On Tue, 10 Jun 2008 03:51:27 GMT, "Ed\(NY\)" <ebny@xxxxxx> wrote: Quote: >When I insert a CD or DVD into one of my two drives, it will play but I >can't get it to eject. The physical drive button doesn't do it, and if I >right click on the drive letter and try "eject" I get an error message. The >only way is to physically insert something in the hole, or reboot. for a short while and decided to just replace the drive. $35 from Newegg with free shipping. Worth it. |
| Guest | Re: DVD Drive problem If this doesn't work do what Nonny said. http://www.grc.com/wizmo/wizmo.htm "Ed(NY)" <ebny@xxxxxx> wrote in message news:3Tm3k.684$Jj1.522@xxxxxx Quote: > When I insert a CD or DVD into one of my two drives, it will play but I > can't get it to eject. The physical drive button doesn't do it, and if I > right click on the drive letter and try "eject" I get an error message. > The only way is to physically insert something in the hole, or reboot. > > Any thoughts? |
| Combo RAID1 and standard Drive setup problem - Unallocated Drive | General Discussion | |||
| DVD-RW drive problem | Vista hardware & devices | |||
| Problem with my DVD-drive | General Discussion | |||
| Problem with DVD/CD RW drive | Vista hardware & devices | |||
| Vista drive has problem, want to copy files to new drive, HOW?? | Vista security | |||
