| | Problem using cell phone USB 13G connection with Win Vista 64bit S I have an LG VX7000 cell phone and Verizon Wireless Mobile Office Kit VERKULG7000 (USB to cell phone cable and software and drivers for 98SE, 2000, ME and XP. I currently use my cell phone on occasion on my HP ZE5470US notebook computer running Windows XP Pro SP3. I have no trouble using the 3G connection or FAX/Modem connection with the cell connected to any USB port on the computer. I just bought an HP DV9830US running Vista 64bit SP1. I plugged my cell phone to the cable and the cable into the USB port and Windows Vista can not configure the phone as a modem. This is a huge problem for me since I occasionally need connectivity when free WiFi or other internet/phone connection is not available. I have been in contact with LG tech support and they say that the cell phone may not be compatable with Vista. LG suggested contacting Verizon Wireless. I contacted Verizon Wireless today and they said that they have had an incredible amount of issues with all of their hardware and software (especially music) related to Vista. Their tech and sales department were not really sure which direction to point me in. Of course, they wanted to sell a phone with internet connectivity built in, which does not help me one bit. As far as I am concerned, I am plugging in a USB device to be used as a modem. Doesn't matter what XP machine I plug it into, it seems to work. But the Vista operating system does not want to recognize this USB modem device (cell phone). I have spent days chasing information by searching on the NET with no success. I really need a solution (simple and free) to getting this new computer with Vista 64bit SP1 connected to the interenet and FAX using my cell phone exactly like I do with my XP Pro SP3 machine. I have had a few other issues so far with the new Vista OS and so far I am not impressed. I'll address those another time. Thanks for any help/solutions! |
| | Re: Problem using cell phone USB 13G connection with Win Vista 64bit S "XammaX" <XammaX@xxxxxx> wrote in message news:523EB402-6FCD-4C14-BD07-464AAAF6E23B@xxxxxx Quote: >I have an LG VX7000 cell phone and Verizon Wireless Mobile Office Kit > VERKULG7000 (USB to cell phone cable and software and drivers for 98SE, > 2000, > ME and XP. I currently use my cell phone on occasion on my HP ZE5470US > notebook computer running Windows XP Pro SP3. I have no trouble using the > 3G > connection or FAX/Modem connection with the cell connected to any USB port > on > the computer. > > I just bought an HP DV9830US running Vista 64bit SP1. I plugged my cell > phone to the cable and the cable into the USB port and Windows Vista can > not > configure the phone as a modem. This is a huge problem for me since I > occasionally need connectivity when free WiFi or other internet/phone > connection is not available. > > I have been in contact with LG tech support and they say that the cell > phone > may not be compatable with Vista. LG suggested contacting Verizon > Wireless. > I contacted Verizon Wireless today and they said that they have had an > incredible amount of issues with all of their hardware and software > (especially music) related to Vista. Their tech and sales department were > not really sure which direction to point me in. Of course, they wanted to > sell a phone with internet connectivity built in, which does not help me > one > bit. > > As far as I am concerned, I am plugging in a USB device to be used as a > modem. Doesn't matter what XP machine I plug it into, it seems to work. > But > the Vista operating system does not want to recognize this USB modem > device > (cell phone). I have spent days chasing information by searching on the > NET > with no success. > > I really need a solution (simple and free) to getting this new computer > with > Vista 64bit SP1 connected to the interenet and FAX using my cell phone > exactly like I do with my XP Pro SP3 machine. > > I have had a few other issues so far with the new Vista OS and so far I am > not impressed. I'll address those another time. > > Thanks for any help/solutions! with an OS that supports it. If the phone manufacturer doesn't understand the problem or what to do to resolve it, it isn't a simple issue. And it's unlikely that you will get a solution from anyone else - the solution may well reside in the phone firmware. This is not at all an unusual circumstance, if you look back at the history of modems with different Windows releases. Many modems stopped working as Windows releases progressed, and had to get updated firmware to work again. What you are experiencing is why, particularly with 64-bit OS versions, it is important to be sure that the devices you want - or need - to use have drivers that are fully supported and tested for that OS version. Sorry there isn't better news. HTH -pk |
| | Re: Problem using cell phone USB 13G connection with Win Vista 64bit S Unfortunately, even though you want it to be simple "As far as I'm concerned ...." but it isn't and cannot be made to be so. The data functionality of the phone relies on drivers that must be made available by LG and Verizon - if they don't have a driver or software install package available for 64-bit Windows then that's that, the phone will not work in Vista and cannot be made to work in Vista. That's not Vista's fault, it's the fault of the hardware manufacturer (LG) for not providing 64-bit support. -- Richard G. Harper [MVP Shell/User] rgharper@xxxxxx * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ "XammaX" <XammaX@xxxxxx> wrote in message news:523EB402-6FCD-4C14-BD07-464AAAF6E23B@xxxxxx Quote: >I have an LG VX7000 cell phone and Verizon Wireless Mobile Office Kit > VERKULG7000 (USB to cell phone cable and software and drivers for 98SE, > 2000, > ME and XP. I currently use my cell phone on occasion on my HP ZE5470US > notebook computer running Windows XP Pro SP3. I have no trouble using the > 3G > connection or FAX/Modem connection with the cell connected to any USB port > on > the computer. > > I just bought an HP DV9830US running Vista 64bit SP1. I plugged my cell > phone to the cable and the cable into the USB port and Windows Vista can > not > configure the phone as a modem. This is a huge problem for me since I > occasionally need connectivity when free WiFi or other internet/phone > connection is not available. > > I have been in contact with LG tech support and they say that the cell > phone > may not be compatable with Vista. LG suggested contacting Verizon > Wireless. > I contacted Verizon Wireless today and they said that they have had an > incredible amount of issues with all of their hardware and software > (especially music) related to Vista. Their tech and sales department were > not really sure which direction to point me in. Of course, they wanted to > sell a phone with internet connectivity built in, which does not help me > one > bit. > > As far as I am concerned, I am plugging in a USB device to be used as a > modem. Doesn't matter what XP machine I plug it into, it seems to work. > But > the Vista operating system does not want to recognize this USB modem > device > (cell phone). I have spent days chasing information by searching on the > NET > with no success. > > I really need a solution (simple and free) to getting this new computer > with > Vista 64bit SP1 connected to the interenet and FAX using my cell phone > exactly like I do with my XP Pro SP3 machine. > > I have had a few other issues so far with the new Vista OS and so far I am > not impressed. I'll address those another time. > > Thanks for any help/solutions! |
| | RE: Problem using cell phone USB 13G connection with Win Vista 64bit S Thanks everyone for the prompt responses. When I was in school, a serial connection was two wires and Ones and Zeros. I guess USB might stand for Uncompatable Software Blunder and not a physical format of hardware connection. I guess planned obsolescence is always part of technology. I just find it hard to believe that a new OS would not be backward compatable. I'd almost bet that Vista will run DOS applications but not a 4 year old cell phone. hahaha I'm still getting 6-10 Meg of updates for my XP every week or so. "Knowledge Base" is a cute way of saying, "Oooops!" Perhaps Bill Gates can put a few of his guys and gals on a program to come up with solutions that get posted on this site to help out some of us that are a bit less financially fortunate than he is. If I could rush out and buy a new cell phone just to fix a Vista software/driver incompatability problem, I would. Kind of like trading in a car for a new one because it's time for an oil change. Can't justify it. My cell works better than a lot of my friend's newer ones. Thanks again and I'm sure you'll see more of me on these discussion groups when I start getting more into this new computer. I'm really not looking forward to it. Max "XammaX" wrote: Quote: > I have an LG VX7000 cell phone and Verizon Wireless Mobile Office Kit > VERKULG7000 (USB to cell phone cable and software and drivers for 98SE, 2000, > ME and XP. I currently use my cell phone on occasion on my HP ZE5470US > notebook computer running Windows XP Pro SP3. I have no trouble using the 3G > connection or FAX/Modem connection with the cell connected to any USB port on > the computer. > > I just bought an HP DV9830US running Vista 64bit SP1. I plugged my cell > phone to the cable and the cable into the USB port and Windows Vista can not > configure the phone as a modem. This is a huge problem for me since I > occasionally need connectivity when free WiFi or other internet/phone > connection is not available. > > I have been in contact with LG tech support and they say that the cell phone > may not be compatable with Vista. LG suggested contacting Verizon Wireless. > I contacted Verizon Wireless today and they said that they have had an > incredible amount of issues with all of their hardware and software > (especially music) related to Vista. Their tech and sales department were > not really sure which direction to point me in. Of course, they wanted to > sell a phone with internet connectivity built in, which does not help me one > bit. > > As far as I am concerned, I am plugging in a USB device to be used as a > modem. Doesn't matter what XP machine I plug it into, it seems to work. But > the Vista operating system does not want to recognize this USB modem device > (cell phone). I have spent days chasing information by searching on the NET > with no success. > > I really need a solution (simple and free) to getting this new computer with > Vista 64bit SP1 connected to the interenet and FAX using my cell phone > exactly like I do with my XP Pro SP3 machine. > > I have had a few other issues so far with the new Vista OS and so far I am > not impressed. I'll address those another time. > > Thanks for any help/solutions! |
| | Re: Problem using cell phone USB 13G connection with Win Vista 64bit S "XammaX" <XammaX@xxxxxx> wrote in message news:598B0124-049C-4227-AD03-758ABE5F7DDF@xxxxxx Quote: > Thanks everyone for the prompt responses. > When I was in school, a serial connection was two wires and Ones and > Zeros. > I guess USB might stand for Uncompatable Software Blunder and not a > physical > format of hardware connection. I guess planned obsolescence is always > part > of technology. > > I just find it hard to believe that a new OS would not be backward > compatable. Quote: > I'd almost bet that Vista will run DOS applications installers. Quote: > but not a 4 > year old cell phone. hahaha I'm still getting 6-10 Meg of updates for my > XP > every week or so. "Knowledge Base" is a cute way of saying, "Oooops!" updates, it's because it's dead in the water. Quote: > > Perhaps Bill Gates Quote: > can put a few of his guys and gals on a program to come > up with solutions that get posted on this site to help out some of us that > are a bit less financially fortunate than he is. If I could rush out and > buy > a new cell phone just to fix a Vista software/driver incompatability > problem, > I would. write the drivers for their systems and devices. MS does not. Quote: > Kind of like trading in a car for a new one because it's time for > an oil change. Can't justify it. My cell works better than a lot of my > friend's newer ones. with Vista64, so that it can't work with your PC's OS. That is LG's problem, not MS's. Quote: > > Thanks again and I'm sure you'll see more of me on these discussion groups > when I start getting more into this new computer. I'm really not looking > forward to it. The point is that you have a responsibility to ensure that the hardware you need to use works with the OS. This information is very seldom secret. If the manufacturer makes an unsupported claim regarding compatibility, that's another story entirely, but the user does have a due-diligence requirement. HTH -pk Quote: > > Max > > "XammaX" wrote: > Quote: >> I have an LG VX7000 cell phone and Verizon Wireless Mobile Office Kit >> VERKULG7000 (USB to cell phone cable and software and drivers for 98SE, >> 2000, >> ME and XP. I currently use my cell phone on occasion on my HP ZE5470US >> notebook computer running Windows XP Pro SP3. I have no trouble using >> the 3G >> connection or FAX/Modem connection with the cell connected to any USB >> port on >> the computer. >> >> I just bought an HP DV9830US running Vista 64bit SP1. I plugged my cell >> phone to the cable and the cable into the USB port and Windows Vista can >> not >> configure the phone as a modem. This is a huge problem for me since I >> occasionally need connectivity when free WiFi or other internet/phone >> connection is not available. >> >> I have been in contact with LG tech support and they say that the cell >> phone >> may not be compatable with Vista. LG suggested contacting Verizon >> Wireless. >> I contacted Verizon Wireless today and they said that they have had an >> incredible amount of issues with all of their hardware and software >> (especially music) related to Vista. Their tech and sales department >> were >> not really sure which direction to point me in. Of course, they wanted >> to >> sell a phone with internet connectivity built in, which does not help me >> one >> bit. >> >> As far as I am concerned, I am plugging in a USB device to be used as a >> modem. Doesn't matter what XP machine I plug it into, it seems to work. >> But >> the Vista operating system does not want to recognize this USB modem >> device >> (cell phone). I have spent days chasing information by searching on the >> NET >> with no success. >> >> I really need a solution (simple and free) to getting this new computer >> with >> Vista 64bit SP1 connected to the interenet and FAX using my cell phone >> exactly like I do with my XP Pro SP3 machine. >> >> I have had a few other issues so far with the new Vista OS and so far I >> am >> not impressed. I'll address those another time. >> >> Thanks for any help/solutions! |
| | #6 (permalink) |
| | Re: Problem using cell phone USB 3G connection with Win Vista 64b Hi Patrick. Having been an electrical engineer for the past 12 years and a systems control engineer, the reasons for standards and specifications are clear. In my industry, by the time we design a control system for a machine, procure the components, build the machine, test it, crate it, ship it, install it. debug it, commission it and turn it over to the customer, the hardware (PC) is outdated already and the software is about three revs behind. But with all the documented testing (pharmaceutical), we can not change the hardware or software since the system has been validated. So when we need to add something to the system, we can not just make these simple changes as change drivers or update the hardware. It simply can not happen without taking the system offline and doing validation testing again. Now, I know LG is not a player in the pharmaceutical field and it is practically their job to terminate support after two years or so on a phone. That is what keeps them selling new phones. But I'd sure hope that when I buy my next computer, I won't have to buy a new external hard drive, printer, scanner, memory stick reader, etc. These are all USB devices. Just like my cell phone. One other thing worth mentioning: I actually have been in companies that still have systems with 5.25" floppy discs for data backup. Most others still have 3.5" floppies. I have one of the last production HP notebook computers running XP that has a pentium processor and a 3.5" floppy drive built in. I have taken it to customer sites instead of my work notebook so I don't have to carry an external USB 3.5" floppy drive with me. Other controller communication interfaces require an actual 9-pin serial port. A USB to 9-pin adaptor will not work. We have had to buy a PCMCIA true serial port in order to connect newer notebook computers to controllers and operator interfaces and even some of those are not 100% compatable. Just imagine if the power companies changed the frequency from 60Hz to something else every five or ten years and you had to go and purhase all new appliences for your home because the old ones would not work. I would think that once the IEEE standard for USB communication was set, that the operating systems and connected devices would follow that communication standard. It doesn't bother me that the hardware gets better and the operating software gets better (or does it?), but sooner or later, communication and interface protocals must remain constant or backward compatable. Technology is changing too rapidly for this not to be the case. So, even though we have had the discussion regarding my issue with my cell phone and I know LG has no intention of writing any drivers for Vista, when you plug a telephone RJ-11 connector into your computer modem and want to dial out or FAX, I'd think you would expect it to work. Wouldn't you? I guess that is my argument and I'm just going to have to stew about it for a while, because until I purchase a new cell phone and a new 2-year contract, I won't have connectivity with the new Vista machine. Thanks for all of the comments and suggestions. Max XammaX "Patrick Keenan" wrote: Quote: > "XammaX" <XammaX@xxxxxx> wrote in message > news:598B0124-049C-4227-AD03-758ABE5F7DDF@xxxxxx Quote: > > Thanks everyone for the prompt responses. > > When I was in school, a serial connection was two wires and Ones and > > Zeros. > > I guess USB might stand for Uncompatable Software Blunder and not a > > physical > > format of hardware connection. I guess planned obsolescence is always > > part > > of technology. > > > > I just find it hard to believe that a new OS would not be backward > > compatable. > Why must it be? > Quote: > > I'd almost bet that Vista will run DOS applications > You might very well be wrong. Vista cannot install apps that use 16-bit > installers. > Quote: > > but not a 4 > > year old cell phone. hahaha I'm still getting 6-10 Meg of updates for my > > XP > > every week or so. "Knowledge Base" is a cute way of saying, "Oooops!" > An OS is an extremely complex work. If you find one with no KB and no > updates, it's because it's dead in the water. > Quote: > > > > Perhaps Bill Gates > Why not LG? > Quote: > > can put a few of his guys and gals on a program to come > > up with solutions that get posted on this site to help out some of us that > > are a bit less financially fortunate than he is. If I could rush out and > > buy > > a new cell phone just to fix a Vista software/driver incompatability > > problem, > > I would. > The repsonsibility could very well lie with LG. *They* are the ones who > write the drivers for their systems and devices. MS does not. > Quote: > > Kind of like trading in a car for a new one because it's time for > > an oil change. Can't justify it. My cell works better than a lot of my > > friend's newer ones. > Except for LG's apparently not having created drivers or firmware that works > with Vista64, so that it can't work with your PC's OS. That is LG's > problem, not MS's. > Quote: > > > > Thanks again and I'm sure you'll see more of me on these discussion groups > > when I start getting more into this new computer. I'm really not looking > > forward to it. > > The point is that you have a responsibility to ensure that the hardware you > need to use works with the OS. This information is very seldom secret. > > If the manufacturer makes an unsupported claim regarding compatibility, > that's another story entirely, but the user does have a due-diligence > requirement. > > HTH > -pk > Quote: > > > > Max > > > > "XammaX" wrote: > > Quote: > >> I have an LG VX7000 cell phone and Verizon Wireless Mobile Office Kit > >> VERKULG7000 (USB to cell phone cable and software and drivers for 98SE, > >> 2000, > >> ME and XP. I currently use my cell phone on occasion on my HP ZE5470US > >> notebook computer running Windows XP Pro SP3. I have no trouble using > >> the 3G > >> connection or FAX/Modem connection with the cell connected to any USB > >> port on > >> the computer. > >> > >> I just bought an HP DV9830US running Vista 64bit SP1. I plugged my cell > >> phone to the cable and the cable into the USB port and Windows Vista can > >> not > >> configure the phone as a modem. This is a huge problem for me since I > >> occasionally need connectivity when free WiFi or other internet/phone > >> connection is not available. > >> > >> I have been in contact with LG tech support and they say that the cell > >> phone > >> may not be compatable with Vista. LG suggested contacting Verizon > >> Wireless. > >> I contacted Verizon Wireless today and they said that they have had an > >> incredible amount of issues with all of their hardware and software > >> (especially music) related to Vista. Their tech and sales department > >> were > >> not really sure which direction to point me in. Of course, they wanted > >> to > >> sell a phone with internet connectivity built in, which does not help me > >> one > >> bit. > >> > >> As far as I am concerned, I am plugging in a USB device to be used as a > >> modem. Doesn't matter what XP machine I plug it into, it seems to work. > >> But > >> the Vista operating system does not want to recognize this USB modem > >> device > >> (cell phone). I have spent days chasing information by searching on the > >> NET > >> with no success. > >> > >> I really need a solution (simple and free) to getting this new computer > >> with > >> Vista 64bit SP1 connected to the interenet and FAX using my cell phone > >> exactly like I do with my XP Pro SP3 machine. > >> > >> I have had a few other issues so far with the new Vista OS and so far I > >> am > >> not impressed. I'll address those another time. > >> > >> Thanks for any help/solutions! > |
| | #7 (permalink) |
| | Re: Problem using cell phone USB 3G connection with Win Vista 64b hello ; I have read about the problems you have had with Vista. I am having the same problems with the MOBILE OFFICE drivers. It is time for upgrading to a new phone. Have you had any luck finding a reasonably priced basic phone that is compatable with Vista and mobile office? "XammaX" wrote: Quote: > Hi Patrick. > > Having been an electrical engineer for the past 12 years and a systems > control engineer, the reasons for standards and specifications are clear. In > my industry, by the time we design a control system for a machine, procure > the components, build the machine, test it, crate it, ship it, install it. > debug it, commission it and turn it over to the customer, the hardware (PC) > is outdated already and the software is about three revs behind. But with > all the documented testing (pharmaceutical), we can not change the hardware > or software since the system has been validated. So when we need to add > something to the system, we can not just make these simple changes as change > drivers or update the hardware. It simply can not happen without taking the > system offline and doing validation testing again. > > Now, I know LG is not a player in the pharmaceutical field and it is > practically their job to terminate support after two years or so on a phone. > That is what keeps them selling new phones. > > But I'd sure hope that when I buy my next computer, I won't have to buy a > new external hard drive, printer, scanner, memory stick reader, etc. These > are all USB devices. Just like my cell phone. > > One other thing worth mentioning: I actually have been in companies that > still have systems with 5.25" floppy discs for data backup. Most others > still have 3.5" floppies. I have one of the last production HP notebook > computers running XP that has a pentium processor and a 3.5" floppy drive > built in. I have taken it to customer sites instead of my work notebook so I > don't have to carry an external USB 3.5" floppy drive with me. Other > controller communication interfaces require an actual 9-pin serial port. A > USB to 9-pin adaptor will not work. We have had to buy a PCMCIA true serial > port in order to connect newer notebook computers to controllers and operator > interfaces and even some of those are not 100% compatable. > > Just imagine if the power companies changed the frequency from 60Hz to > something else every five or ten years and you had to go and purhase all new > appliences for your home because the old ones would not work. > > I would think that once the IEEE standard for USB communication was set, > that the operating systems and connected devices would follow that > communication standard. It doesn't bother me that the hardware gets better > and the operating software gets better (or does it?), but sooner or later, > communication and interface protocals must remain constant or backward > compatable. Technology is changing too rapidly for this not to be the case. > > So, even though we have had the discussion regarding my issue with my cell > phone and I know LG has no intention of writing any drivers for Vista, when > you plug a telephone RJ-11 connector into your computer modem and want to > dial out or FAX, I'd think you would expect it to work. Wouldn't you? I > guess that is my argument and I'm just going to have to stew about it for a > while, because until I purchase a new cell phone and a new 2-year contract, I > won't have connectivity with the new Vista machine. > > Thanks for all of the comments and suggestions. > > Max > > XammaX > > > > "Patrick Keenan" wrote: > Quote: > > "XammaX" <XammaX@xxxxxx> wrote in message > > news:598B0124-049C-4227-AD03-758ABE5F7DDF@xxxxxx Quote: > > > Thanks everyone for the prompt responses. > > > When I was in school, a serial connection was two wires and Ones and > > > Zeros. > > > I guess USB might stand for Uncompatable Software Blunder and not a > > > physical > > > format of hardware connection. I guess planned obsolescence is always > > > part > > > of technology. > > > > > > I just find it hard to believe that a new OS would not be backward > > > compatable. > > Why must it be? > > Quote: > > > I'd almost bet that Vista will run DOS applications > > You might very well be wrong. Vista cannot install apps that use 16-bit > > installers. > > Quote: > > > but not a 4 > > > year old cell phone. hahaha I'm still getting 6-10 Meg of updates for my > > > XP > > > every week or so. "Knowledge Base" is a cute way of saying, "Oooops!" > > An OS is an extremely complex work. If you find one with no KB and no > > updates, it's because it's dead in the water. > > Quote: > > > > > > Perhaps Bill Gates > > Why not LG? > > Quote: > > > can put a few of his guys and gals on a program to come > > > up with solutions that get posted on this site to help out some of us that > > > are a bit less financially fortunate than he is. If I could rush out and > > > buy > > > a new cell phone just to fix a Vista software/driver incompatability > > > problem, > > > I would. > > The repsonsibility could very well lie with LG. *They* are the ones who > > write the drivers for their systems and devices. MS does not. > > Quote: > > > Kind of like trading in a car for a new one because it's time for > > > an oil change. Can't justify it. My cell works better than a lot of my > > > friend's newer ones. > > Except for LG's apparently not having created drivers or firmware that works > > with Vista64, so that it can't work with your PC's OS. That is LG's > > problem, not MS's. > > Quote: > > > > > > Thanks again and I'm sure you'll see more of me on these discussion groups > > > when I start getting more into this new computer. I'm really not looking > > > forward to it. > > > > The point is that you have a responsibility to ensure that the hardware you > > need to use works with the OS. This information is very seldom secret. > > > > If the manufacturer makes an unsupported claim regarding compatibility, > > that's another story entirely, but the user does have a due-diligence > > requirement. > > > > HTH > > -pk > > Quote: > > > > > > Max > > > > > > "XammaX" wrote: > > > > > >> I have an LG VX7000 cell phone and Verizon Wireless Mobile Office Kit > > >> VERKULG7000 (USB to cell phone cable and software and drivers for 98SE, > > >> 2000, > > >> ME and XP. I currently use my cell phone on occasion on my HP ZE5470US > > >> notebook computer running Windows XP Pro SP3. I have no trouble using > > >> the 3G > > >> connection or FAX/Modem connection with the cell connected to any USB > > >> port on > > >> the computer. > > >> > > >> I just bought an HP DV9830US running Vista 64bit SP1. I plugged my cell > > >> phone to the cable and the cable into the USB port and Windows Vista can > > >> not > > >> configure the phone as a modem. This is a huge problem for me since I > > >> occasionally need connectivity when free WiFi or other internet/phone > > >> connection is not available. > > >> > > >> I have been in contact with LG tech support and they say that the cell > > >> phone > > >> may not be compatable with Vista. LG suggested contacting Verizon > > >> Wireless. > > >> I contacted Verizon Wireless today and they said that they have had an > > >> incredible amount of issues with all of their hardware and software > > >> (especially music) related to Vista. Their tech and sales department > > >> were > > >> not really sure which direction to point me in. Of course, they wanted > > >> to > > >> sell a phone with internet connectivity built in, which does not help me > > >> one > > >> bit. > > >> > > >> As far as I am concerned, I am plugging in a USB device to be used as a > > >> modem. Doesn't matter what XP machine I plug it into, it seems to work. > > >> But > > >> the Vista operating system does not want to recognize this USB modem > > >> device > > >> (cell phone). I have spent days chasing information by searching on the > > >> NET > > >> with no success. > > >> > > >> I really need a solution (simple and free) to getting this new computer > > >> with > > >> Vista 64bit SP1 connected to the interenet and FAX using my cell phone > > >> exactly like I do with my XP Pro SP3 machine. > > >> > > >> I have had a few other issues so far with the new Vista OS and so far I > > >> am > > >> not impressed. I'll address those another time. > > >> > > >> Thanks for any help/solutions! > > |
| | #8 (permalink) |
| | Re: Problem using cell phone USB 3G connection with Win Vista 64b Hi Rocknc: I have not looked into purchasing a new cell phone. I don't have the money right now to do that. I think that is a concept that MS and LG don't understand. Hopefully you can find an economical phone that is compatable with Vista. I just hope that if you find a new phone that works with Vista now, that it will still work with Vista when they release Service Pack 2. It seems we should have no expectation that any hardware should work after software improvements. Max XammaX "Rocknc" wrote: Quote: > hello ; I have read about the problems you have had with Vista. I am having > the same problems with the MOBILE OFFICE drivers. It is time for upgrading to > a new phone. Have you had any luck finding a reasonably priced basic phone > that is compatable with Vista and mobile office? > > "XammaX" wrote: > Quote: > > Hi Patrick. > > > > Having been an electrical engineer for the past 12 years and a systems > > control engineer, the reasons for standards and specifications are clear. In > > my industry, by the time we design a control system for a machine, procure > > the components, build the machine, test it, crate it, ship it, install it. > > debug it, commission it and turn it over to the customer, the hardware (PC) > > is outdated already and the software is about three revs behind. But with > > all the documented testing (pharmaceutical), we can not change the hardware > > or software since the system has been validated. So when we need to add > > something to the system, we can not just make these simple changes as change > > drivers or update the hardware. It simply can not happen without taking the > > system offline and doing validation testing again. > > > > Now, I know LG is not a player in the pharmaceutical field and it is > > practically their job to terminate support after two years or so on a phone. > > That is what keeps them selling new phones. > > > > But I'd sure hope that when I buy my next computer, I won't have to buy a > > new external hard drive, printer, scanner, memory stick reader, etc. These > > are all USB devices. Just like my cell phone. > > > > One other thing worth mentioning: I actually have been in companies that > > still have systems with 5.25" floppy discs for data backup. Most others > > still have 3.5" floppies. I have one of the last production HP notebook > > computers running XP that has a pentium processor and a 3.5" floppy drive > > built in. I have taken it to customer sites instead of my work notebook so I > > don't have to carry an external USB 3.5" floppy drive with me. Other > > controller communication interfaces require an actual 9-pin serial port. A > > USB to 9-pin adaptor will not work. We have had to buy a PCMCIA true serial > > port in order to connect newer notebook computers to controllers and operator > > interfaces and even some of those are not 100% compatable. > > > > Just imagine if the power companies changed the frequency from 60Hz to > > something else every five or ten years and you had to go and purhase all new > > appliences for your home because the old ones would not work. > > > > I would think that once the IEEE standard for USB communication was set, > > that the operating systems and connected devices would follow that > > communication standard. It doesn't bother me that the hardware gets better > > and the operating software gets better (or does it?), but sooner or later, > > communication and interface protocals must remain constant or backward > > compatable. Technology is changing too rapidly for this not to be the case. > > > > So, even though we have had the discussion regarding my issue with my cell > > phone and I know LG has no intention of writing any drivers for Vista, when > > you plug a telephone RJ-11 connector into your computer modem and want to > > dial out or FAX, I'd think you would expect it to work. Wouldn't you? I > > guess that is my argument and I'm just going to have to stew about it for a > > while, because until I purchase a new cell phone and a new 2-year contract, I > > won't have connectivity with the new Vista machine. > > > > Thanks for all of the comments and suggestions. > > > > Max > > > > XammaX > > > > > > > > "Patrick Keenan" wrote: > > Quote: > > > "XammaX" <XammaX@xxxxxx> wrote in message > > > news:598B0124-049C-4227-AD03-758ABE5F7DDF@xxxxxx > > > > Thanks everyone for the prompt responses. > > > > When I was in school, a serial connection was two wires and Ones and > > > > Zeros. > > > > I guess USB might stand for Uncompatable Software Blunder and not a > > > > physical > > > > format of hardware connection. I guess planned obsolescence is always > > > > part > > > > of technology. > > > > > > > > I just find it hard to believe that a new OS would not be backward > > > > compatable. > > > > > > Why must it be? > > > > > > > I'd almost bet that Vista will run DOS applications > > > > > > You might very well be wrong. Vista cannot install apps that use 16-bit > > > installers. > > > > > > > but not a 4 > > > > year old cell phone. hahaha I'm still getting 6-10 Meg of updates for my > > > > XP > > > > every week or so. "Knowledge Base" is a cute way of saying, "Oooops!" > > > > > > An OS is an extremely complex work. If you find one with no KB and no > > > updates, it's because it's dead in the water. > > > > > > > > > > > Perhaps Bill Gates > > > > > > Why not LG? > > > > > > > can put a few of his guys and gals on a program to come > > > > up with solutions that get posted on this site to help out some of us that > > > > are a bit less financially fortunate than he is. If I could rush out and > > > > buy > > > > a new cell phone just to fix a Vista software/driver incompatability > > > > problem, > > > > I would. > > > > > > The repsonsibility could very well lie with LG. *They* are the ones who > > > write the drivers for their systems and devices. MS does not. > > > > > > > Kind of like trading in a car for a new one because it's time for > > > > an oil change. Can't justify it. My cell works better than a lot of my > > > > friend's newer ones. > > > > > > Except for LG's apparently not having created drivers or firmware that works > > > with Vista64, so that it can't work with your PC's OS. That is LG's > > > problem, not MS's. > > > > > > > > > > > Thanks again and I'm sure you'll see more of me on these discussion groups > > > > when I start getting more into this new computer. I'm really not looking > > > > forward to it. > > > > > > > > > The point is that you have a responsibility to ensure that the hardware you > > > need to use works with the OS. This information is very seldom secret. > > > > > > If the manufacturer makes an unsupported claim regarding compatibility, > > > that's another story entirely, but the user does have a due-diligence > > > requirement. > > > > > > HTH > > > -pk > > > > > > > > > > > Max > > > > > > > > "XammaX" wrote: > > > > > > > >> I have an LG VX7000 cell phone and Verizon Wireless Mobile Office Kit > > > >> VERKULG7000 (USB to cell phone cable and software and drivers for 98SE, > > > >> 2000, > > > >> ME and XP. I currently use my cell phone on occasion on my HP ZE5470US > > > >> notebook computer running Windows XP Pro SP3. I have no trouble using > > > >> the 3G > > > >> connection or FAX/Modem connection with the cell connected to any USB > > > >> port on > > > >> the computer. > > > >> > > > >> I just bought an HP DV9830US running Vista 64bit SP1. I plugged my cell > > > >> phone to the cable and the cable into the USB port and Windows Vista can > > > >> not > > > >> configure the phone as a modem. This is a huge problem for me since I > > > >> occasionally need connectivity when free WiFi or other internet/phone > > > >> connection is not available. > > > >> > > > >> I have been in contact with LG tech support and they say that the cell > > > >> phone > > > >> may not be compatable with Vista. LG suggested contacting Verizon > > > >> Wireless. > > > >> I contacted Verizon Wireless today and they said that they have had an > > > >> incredible amount of issues with all of their hardware and software > > > >> (especially music) related to Vista. Their tech and sales department > > > >> were > > > >> not really sure which direction to point me in. Of course, they wanted > > > >> to > > > >> sell a phone with internet connectivity built in, which does not help me > > > >> one > > > >> bit. > > > >> > > > >> As far as I am concerned, I am plugging in a USB device to be used as a > > > >> modem. Doesn't matter what XP machine I plug it into, it seems to work. > > > >> But > > > >> the Vista operating system does not want to recognize this USB modem > > > >> device > > > >> (cell phone). I have spent days chasing information by searching on the > > > >> NET > > > >> with no success. > > > >> > > > >> I really need a solution (simple and free) to getting this new computer > > > >> with > > > >> Vista 64bit SP1 connected to the interenet and FAX using my cell phone > > > >> exactly like I do with my XP Pro SP3 machine. > > > >> > > > >> I have had a few other issues so far with the new Vista OS and so far I > > > >> am > > > >> not impressed. I'll address those another time. > > > >> > > > >> Thanks for any help/solutions! > > > > > > |
| | #9 (permalink) |
| | Re: Problem using cell phone USB 3G connection with Win Vista 64b X: Tethered fones via USB are nothing more than a USB modem that responds to std. AT commands and the AT superset that controls digital data specifically. That being the case, I wonder if ANY USB fone driver might work for your fone IF you know how the properly edit the .INF file for it. All said "driver" would need to do is make the fone look like a serial port. That's all. All the rest is handled by setting up a Connection for it in Network Connections and then issuing AT commands. I don't run Vista any more (too many problems) but I wonder if there are any USB modems in its internal list of modems that you might be able to modify the .INF file for. Just a thought if you're up to the challenge... What exactly happens when you plug it in, anyway? What errors do you get and what does it say about it in Device Manager? "XammaX" <XammaX@xxxxxx> wrote in message news:23AFF269-0D77-44E6-BA92-11B8E2E2930E@xxxxxx Quote: > Hi Rocknc: > > I have not looked into purchasing a new cell phone. I don't have the money > right now to do that. I think that is a concept that MS and LG don't > understand. > > Hopefully you can find an economical phone that is compatable with Vista. I > just hope that if you find a new phone that works with Vista now, that it > will still work with Vista when they release Service Pack 2. It seems we > should have no expectation that any hardware should work after software > improvements. > > Max > XammaX > > > "Rocknc" wrote: > Quote: > > hello ; I have read about the problems you have had with Vista. I am having > > the same problems with the MOBILE OFFICE drivers. It is time for upgrading Quote: Quote: > > a new phone. Have you had any luck finding a reasonably priced basic phone > > that is compatable with Vista and mobile office? > > > > "XammaX" wrote: > > Quote: > > > Hi Patrick. > > > > > > Having been an electrical engineer for the past 12 years and a systems > > > control engineer, the reasons for standards and specifications are clear. Quote: Quote: Quote: > > > my industry, by the time we design a control system for a machine, procure > > > the components, build the machine, test it, crate it, ship it, install it. > > > debug it, commission it and turn it over to the customer, the hardware Quote: Quote: Quote: > > > is outdated already and the software is about three revs behind. But with > > > all the documented testing (pharmaceutical), we can not change the Quote: Quote: Quote: > > > or software since the system has been validated. So when we need to add > > > something to the system, we can not just make these simple changes as Quote: Quote: Quote: > > > drivers or update the hardware. It simply can not happen without taking Quote: Quote: Quote: > > > system offline and doing validation testing again. > > > > > > Now, I know LG is not a player in the pharmaceutical field and it is > > > practically their job to terminate support after two years or so on a Quote: Quote: Quote: > > > That is what keeps them selling new phones. > > > > > > But I'd sure hope that when I buy my next computer, I won't have to buy a > > > new external hard drive, printer, scanner, memory stick reader, etc. Quote: Quote: Quote: > > > are all USB devices. Just like my cell phone. > > > > > > One other thing worth mentioning: I actually have been in companies that > > > still have systems with 5.25" floppy discs for data backup. Most others > > > still have 3.5" floppies. I have one of the last production HP notebook > > > computers running XP that has a pentium processor and a 3.5" floppy drive > > > built in. I have taken it to customer sites instead of my work notebook Quote: Quote: Quote: > > > don't have to carry an external USB 3.5" floppy drive with me. Other > > > controller communication interfaces require an actual 9-pin serial port. Quote: Quote: Quote: > > > USB to 9-pin adaptor will not work. We have had to buy a PCMCIA true Quote: Quote: Quote: > > > port in order to connect newer notebook computers to controllers and Quote: Quote: Quote: > > > interfaces and even some of those are not 100% compatable. > > > > > > Just imagine if the power companies changed the frequency from 60Hz to > > > something else every five or ten years and you had to go and purhase all Quote: Quote: Quote: > > > appliences for your home because the old ones would not work. > > > > > > I would think that once the IEEE standard for USB communication was set, > > > that the operating systems and connected devices would follow that > > > communication standard. It doesn't bother me that the hardware gets Quote: Quote: Quote: > > > and the operating software gets better (or does it?), but sooner or later, > > > communication and interface protocals must remain constant or backward > > > compatable. Technology is changing too rapidly for this not to be the Quote: Quote: Quote: > > > > > > So, even though we have had the discussion regarding my issue with my cell > > > phone and I know LG has no intention of writing any drivers for Vista, Quote: Quote: Quote: > > > you plug a telephone RJ-11 connector into your computer modem and want to > > > dial out or FAX, I'd think you would expect it to work. Wouldn't you? I > > > guess that is my argument and I'm just going to have to stew about it for Quote: Quote: Quote: > > > while, because until I purchase a new cell phone and a new 2-year Quote: Quote: Quote: > > > won't have connectivity with the new Vista machine. > > > > > > Thanks for all of the comments and suggestions. > > > > > > Max > > > > > > XammaX > > > > > > > > > > > > "Patrick Keenan" wrote: > > > > > > > "XammaX" <XammaX@xxxxxx> wrote in message > > > > news:598B0124-049C-4227-AD03-758ABE5F7DDF@xxxxxx > > > > > Thanks everyone for the prompt responses. > > > > > When I was in school, a serial connection was two wires and Ones and > > > > > Zeros. > > > > > I guess USB might stand for Uncompatable Software Blunder and not a > > > > > physical > > > > > format of hardware connection. I guess planned obsolescence is always > > > > > part > > > > > of technology. > > > > > > > > > > I just find it hard to believe that a new OS would not be backward > > > > > compatable. > > > > > > > > Why must it be? > > > > > > > > > I'd almost bet that Vista will run DOS applications > > > > > > > > You might very well be wrong. Vista cannot install apps that use Quote: Quote: Quote: > > > > installers. > > > > > > > > > but not a 4 > > > > > year old cell phone. hahaha I'm still getting 6-10 Meg of updates Quote: Quote: Quote: > > > > > XP > > > > > every week or so. "Knowledge Base" is a cute way of saying, "Oooops!" > > > > > > > > An OS is an extremely complex work. If you find one with no KB and no > > > > updates, it's because it's dead in the water. > > > > > > > > > > > > > > Perhaps Bill Gates > > > > > > > > Why not LG? > > > > > > > > > can put a few of his guys and gals on a program to come > > > > > up with solutions that get posted on this site to help out some of us Quote: Quote: Quote: > > > > > are a bit less financially fortunate than he is. If I could rush out Quote: Quote: Quote: > > > > > buy > > > > > a new cell phone just to fix a Vista software/driver incompatability > > > > > problem, > > > > > I would. > > > > > > > > The repsonsibility could very well lie with LG. *They* are the ones Quote: Quote: Quote: > > > > write the drivers for their systems and devices. MS does not. > > > > > > > > > Kind of like trading in a car for a new one because it's time for > > > > > an oil change. Can't justify it. My cell works better than a lot of Quote: Quote: Quote: > > > > > friend's newer ones. > > > > > > > > Except for LG's apparently not having created drivers or firmware that Quote: Quote: Quote: > > > > with Vista64, so that it can't work with your PC's OS. That is LG's > > > > problem, not MS's. > > > > > > > > > > > > > > Thanks again and I'm sure you'll see more of me on these discussion Quote: Quote: Quote: > > > > > when I start getting more into this new computer. I'm really not Quote: Quote: Quote: > > > > > forward to it. > > > > > > > > > > > > The point is that you have a responsibility to ensure that the hardware Quote: Quote: Quote: > > > > need to use works with the OS. This information is very seldom secret. > > > > > > > > If the manufacturer makes an unsupported claim regarding compatibility, > > > > that's another story entirely, but the user does have a due-diligence > > > > requirement. > > > > > > > > HTH > > > > -pk > > > > > > > > > > > > > > Max > > > > > > > > > > "XammaX" wrote: > > > > > > > > > >> I have an LG VX7000 cell phone and Verizon Wireless Mobile Office Kit > > > > >> VERKULG7000 (USB to cell phone cable and software and drivers for Quote: Quote: Quote: > > > > >> 2000, > > > > >> ME and XP. I currently use my cell phone on occasion on my HP Quote: Quote: Quote: > > > > >> notebook computer running Windows XP Pro SP3. I have no trouble Quote: Quote: Quote: > > > > >> the 3G > > > > >> connection or FAX/Modem connection with the cell connected to any USB > > > > >> port on > > > > >> the computer. > > > > >> > > > > >> I just bought an HP DV9830US running Vista 64bit SP1. I plugged my Quote: Quote: Quote: > > > > >> phone to the cable and the cable into the USB port and Windows Vista Quote: Quote: Quote: > > > > >> not > > > > >> configure the phone as a modem. This is a huge problem for me since Quote: Quote: Quote: > > > > >> occasionally need connectivity when free WiFi or other internet/phone > > > > >> connection is not available. > > > > >> > > > > >> I have been in contact with LG tech support and they say that the Quote: Quote: Quote: > > > > >> phone > > > > >> may not be compatable with Vista. LG suggested contacting Verizon > > > > >> Wireless. > > > > >> I contacted Verizon Wireless today and they said that they have had Quote: Quote: Quote: > > > > >> incredible amount of issues with all of their hardware and software > > > > >> (especially music) related to Vista. Their tech and sales department > > > > >> were > > > > >> not really sure which direction to point me in. Of course, they Quote: Quote: Quote: > > > > >> to > > > > >> sell a phone with internet connectivity built in, which does not help Quote: Quote: Quote: > > > > >> one > > > > >> bit. > > > > >> > > > > >> As far as I am concerned, I am plugging in a USB device to be used as Quote: Quote: Quote: > > > > >> modem. Doesn't matter what XP machine I plug it into, it seems to Quote: Quote: Quote: > > > > >> But > > > > >> the Vista operating system does not want to recognize this USB modem > > > > >> device > > > > >> (cell phone). I have spent days chasing information by searching on Quote: Quote: Quote: > > > > >> NET > > > > >> with no success. > > > > >> > > > > >> I really need a solution (simple and free) to getting this new Quote: Quote: Quote: > > > > >> with > > > > >> Vista 64bit SP1 connected to the interenet and FAX using my cell Quote: Quote: Quote: > > > > >> exactly like I do with my XP Pro SP3 machine. > > > > >> > > > > >> I have had a few other issues so far with the new Vista OS and so far Quote: Quote: Quote: > > > > >> am > > > > >> not impressed. I'll address those another time. > > > > >> > > > > >> Thanks for any help/solutions! > > > > > > > > |
| Sync my cell phone | Network & Sharing | |||
| syncing to cell phone | Vista music pictures video | |||
| Vista 64 not recognize my cell phone and burns up flashdrives | Vista hardware & devices | |||
| Choosing a new cell phone | Vista General | |||
| Motorola Razr V3c and Build 6000 Don't Mix (Recently Got a Cell Phone Virus while trying to set up Motorola Phone Tools 4.0) | Vista General | |||
