| Guest | System restore and other system apps do not work I am using Vista Ultimate x64 Build 6001 SP1. Intel® Core(TM)2 CPU 6700 @ 2.66GHz 2.66 GHz Memory (RAM) 4.00 GB The behavior described below started suddenly, possibly after the installation of an update. Some of the symptoms are: When I click on System Restore I get (as expected) the dialog box “Windows needs your permission to continue” I click Continue. Apparently nothing happens. I repeat the above and I get the message “The System Restore wizard is already running.” However, it is not visible. Task Manager also remains invisible. When I click on “Turn Windows features on and off” the “Windows Features” box is displayed with “Please wait...” but nothing happens. When trying to uninstall an update, Windows Installer displays "Preparing to install..." and remains so forever. Click Cancel, after 10 min or so “Install server is not responding”. At times Visual Studio and the Office 2007 programs go in No responding mode and I must reboot. When I shut down the computer "Logging off " is displayed until I use the hardware shut down button. Chkdsk found nothing wrong. Sfc /scannow doesn’t start; the cursor is blinking on the next line for ever. The same in Safe Mode. When I try to start from the DVD the Vista background is displayed with the mouse cursor but then nothing. Is there a way out? Thanks, Dan |
| Guest | Re: System restore and other system apps do not work Dan wrote: Quote: > I am using Vista Ultimate x64 Build 6001 SP1. > Intel Core(TM)2 CPU 6700 @ 2.66GHz 2.66 GHz Memory (RAM) 4.00 GB > The behavior described below started suddenly, possibly after the > installation of an update. > Some of the symptoms are: > > When I click on System Restore I get (as expected) the dialog box ?Windows > needs your permission to continue? > I click Continue. Apparently nothing happens. > I repeat the above and I get the message ?The System Restore wizard is > already running.? However, it is not visible. > > Task Manager also remains invisible. > > When I click on ?Turn Windows features on and off? the ?Windows Features? > box is displayed with ?Please wait...? but nothing happens. > > When trying to uninstall an update, Windows Installer displays "Preparing > to install..." and remains so forever. Click Cancel, after 10 min or so > ?Install server is not responding?. > > At times Visual Studio and the Office 2007 programs go in No responding > mode and I must reboot. > > When I shut down the computer "Logging off " is displayed until I use > the hardware shut down button. > > Chkdsk found nothing wrong. > > Sfc /scannow doesn?t start; the cursor is blinking on the next line for > ever. > > The same in Safe Mode. > > When I try to start from the DVD the Vista background is displayed with > the mouse cursor but then nothing. describing can certainly be caused by infection. Here are some general removal steps: http://www.elephantboycomputers.com/...moving_Malware Be thorough. As said at that link, you should get all tools and their updates from a different, known-clean machine and you should do all work in Safe Mode. 2. If after you've done your thorough scanning you find the machine to be clean, I would do a System Restore to when things worked since the change was recent and sudden. To run System Restore, go to the Start Orb and in the Start Search box type "System Restore" without the quotes. System Restore will appear in the Programs result. Click on it, allow the UAC prompt, and follow the wizard. (Note: You will be tempted to run System Restore before making sure your computer is clean because it is less work. It isn't what I would do, but naturally what you do is your choice.) 3. If the machine is clean and System Restore doesn't help, I'd next look at the hardware to make sure it is sound. I'd start with the hard drive. http://www.elephantboycomputers.com/...ardware_Tshoot Malke -- MS-MVP Elephant Boy Computers www.elephantboycomputers.com Don't Panic! |
| Guest | Re: System restore and other system apps do not work Many thanks Malke for your very comprehensive reply. Your website is also impressive and I started applying those hints. Strangely enough Safe Mode is not usable because Windows Explorer does not start. As I mentioned in normal mode most programs work (exceptions those mentioned). Thanks again, Dan "Malke" wrote: Quote: > Dan wrote: > Quote: > > I am using Vista Ultimate x64 Build 6001 SP1. > > Intel® Core(TM)2 CPU 6700 @ 2.66GHz 2.66 GHz Memory (RAM) 4.00 GB > > The behavior described below started suddenly, possibly after the > > installation of an update. > > Some of the symptoms are: > > > > When I click on System Restore I get (as expected) the dialog box ?Windows > > needs your permission to continue? > > I click Continue. Apparently nothing happens. > > I repeat the above and I get the message ?The System Restore wizard is > > already running.? However, it is not visible. > > > > Task Manager also remains invisible. > > > > When I click on ?Turn Windows features on and off? the ?Windows Features? > > box is displayed with ?Please wait...? but nothing happens. > > > > When trying to uninstall an update, Windows Installer displays "Preparing > > to install..." and remains so forever. Click Cancel, after 10 min or so > > ?Install server is not responding?. > > > > At times Visual Studio and the Office 2007 programs go in No responding > > mode and I must reboot. > > > > When I shut down the computer "Logging off " is displayed until I use > > the hardware shut down button. > > > > Chkdsk found nothing wrong. > > > > Sfc /scannow doesn?t start; the cursor is blinking on the next line for > > ever. > > > > The same in Safe Mode. > > > > When I try to start from the DVD the Vista background is displayed with > > the mouse cursor but then nothing. > 1. Make sure the computer is virus/malware-free. The symptoms you are > describing can certainly be caused by infection. Here are some general > removal steps: > > http://www.elephantboycomputers.com/...moving_Malware > > Be thorough. As said at that link, you should get all tools and their > updates from a different, known-clean machine and you should do all work in > Safe Mode. > > 2. If after you've done your thorough scanning you find the machine to be > clean, I would do a System Restore to when things worked since the change > was recent and sudden. To run System Restore, go to the Start Orb and in > the Start Search box type "System Restore" without the quotes. System > Restore will appear in the Programs result. Click on it, allow the UAC > prompt, and follow the wizard. > > (Note: You will be tempted to run System Restore before making sure your > computer is clean because it is less work. It isn't what I would do, but > naturally what you do is your choice.) > > 3. If the machine is clean and System Restore doesn't help, I'd next look at > the hardware to make sure it is sound. I'd start with the hard drive. > > http://www.elephantboycomputers.com/...ardware_Tshoot > > Malke > -- > MS-MVP > Elephant Boy Computers > www.elephantboycomputers.com > Don't Panic! > |
| System Restore doesn't work | Vista General | |||
| System Restore Won't Work | General Discussion | |||
| Does system restore really work? | Vista General | |||
| System Restore does not work | Vista General | |||
| System Restore Doesn't Work | Vista General | |||
