Vista Forums Home Join Vista Forums Tech Publications Windows 7 Forum Vista Tutorials Webcasts Tags
Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Problem Reports and Solutions
Update your Vista Drivers
Thread Tools Display Modes
Old 06-13-2008   #1 (permalink)
GillB
Guest
I have never had any luck with the above programme. I check for new solutions
to various problems which can vary from 3 to 56 problems in total yet every
time I run check for solutions I get the same message(there are no solutions
at this time, please try again later) If there are never any solutions what
is the point of this programme at all?
Old 06-13-2008   #2 (permalink)
Knowledge Worker
Guest
Re: Problem Reports and Solutions
I would agree with Gill!
The Problem Reports and Solutions has not helped me out yet in any way
The following is the information I found
http://technet2.microsoft.com/Window....mspx?mfr=true
Not very helpful!!
"GillB" <GillB@xxxxxx> wrote in message
news:4AB33680-AB53-416E-BA36-43C2C07D001F@xxxxxx
> solutions
> every
> solutions
> what
Old 06-21-2008   #3 (permalink)
zachd [MSFT]
Guest
What areas are you crashing in?
What's a couple sample fault bucket numbers from your crashes?
There are often solutions available. Reports get sent, things get looked
into. I help on some of this stuff as a hobby (there are teams that do that
as a job, I just consider it another way to help improve the Windows
ecosystem), and sometimes it can take a while to drill down to the exact
cause and then you need to follow up to get the right solution in place,
etc.
It should be pretty highly beneficial to the computing ecosystem over time,
but there's never any magic bullet solution that just makes crashes go away.
Anyways, post up the problem reports you're dealing with and I'll take a
look.
Speaking for myself only.
See http://zachd.com/pss/pss.html for some helpful WMP info.
>solutions
> every
> solutions
> what
Old 07-18-2008   #4 (permalink)
zachd [MSFT]
Guest
What are the specific details of the faults/crashes that you're running
into:
http://zachd.com/pss/pss.html#bucket
Given that data for like maybe 5-10 of them (fault data and or fault bucket
number would be great), I'd suspect I could probably help get you moving on
at least some of them.
>solutions
> every
> solutions
> what
Display Modes
Problem Reports and Solutions.....? Dirty Dawg Vista performance & maintenance 1 07-24-2008 06:06 AM
Problem Reports and Solutions KB Clayton Vista General 7 01-05-2008 02:35 AM
Problem Reports and Solutions Caillah Vista General 1 05-09-2007 08:11 PM
Problem Reports & Solutions Larry S Vista account administration 0 02-09-2007 09:41 PM
Problem Reports and Solutions =?Utf-8?B?UmFuZHkgSy4=?= Vista performance & maintenance 2 07-09-2006 04:37 PM
Complimentary Industry Resources
Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today!
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
