Vista - problems with battery´s icon
Old 06-14-2008   #1 (permalink)
Clara Cagigal
Hallo, after installing sp1 in my hp compaq 6720s laptop with vista home
premium preinstalled, i
have observed the following problem:
Sometimes when i turn on the laptop or reinitiate it, the battery´s icon in
the notification area of the task bar, appears empty as it would be
discharged, which is not certain because it says 99% available, connected
and without charging. I used to solve the problem reinitiating the computer
because ticking in the battery icon in notification area of properties in
task bar doesn´t solve it.
¿Does anybody knows what is the cause of the problem and how to solve it
without reinitiating?
Thanks in advance
Regards
Clara
Battery Icon Missing? Vista General
my battery icon has gone Vista General
Battery Icon Vista General
Battery Icon Flashing Vista performance & maintenance
Lost Battery Icon Vista General
