Vista - File Path Problem
Old 06-14-2008   #1 (permalink)
Rpower
File Path Problem
I have reciently started to use windows vista and am now very familiar with
all parts of it but there is one problem I wish to find out more about. In
windows XP the "My Documents folder was lacated in a very logical place, on
vista it is just called "Documents" and is arranged differently. My images
and music etc are seperate from Documents folder and are all subfolders in my
user profile.
My question is: Is this path for Documents folder correct or should it be
located in another place: "C:\Users\Users Name\Saved Games\Documents ?
The R G
Old 06-14-2008   #2 (permalink)
PaulB
RE: File Path Problem
I would not consider this a problem but to each his own. To me this file
arrangement is very logical. I have a user folder ,my user name, and all my
documents, downloads, music, etc. are located there.
Paul
> user profile.
> The R G
Old 06-14-2008   #3 (permalink)
John Inzer
Re: File Path Problem
Rpower wrote:
> familiar with all parts of it but there is one problem I wish to find
> out more about. In windows XP the "My Documents folder was lacated in
> a very logical place, on vista it is just called "Documents" and is
> arranged differently. My images and music etc are seperate from
> Documents folder and are all subfolders in my user profile.
> it be located in another place: "C:\Users\Users Name\Saved
> Games\Documents ?
C:\Users\Users Name\Documents
C:\Users\Users Name\Pictures
C:\Users\Users Name\Music
There is also a default folder at the following path:
Maybe your Documents folder was dragged
into the Saved Games folder by accident.
John Inzer
Digital Media MVP
Notice
This is not tech support
I am a volunteer
Solutions that work for
me may not work for you
Proceed at your own risk
Old 06-14-2008   #4 (permalink)
Nonny
On Sat, 14 Jun 2008 06:50:00 -0700, Rpower
>user profile.
There is no logical reason why it should be under "Saved Games".
Old 06-14-2008   #5 (permalink)
Mark L. Ferguson
It's possible to modify the registry entry for "Documents" anywhere you want
it.
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User
Shell Folders
"Personal" = %USERPROFILE%\Documents
click the Ratings button. Voting helps the web interface.
http://www.microsoft.com/wn3/locales...help_en-us.htm see ''rate a post''
Mark L. Ferguson
"Rpower" <Rpower@xxxxxx> wrote in message
news:40874282-F337-4143-B4D8-92E7B23A00C2@xxxxxx
> with
> on
> my
> user profile.
> The R G
Old 06-15-2008   #6 (permalink)
Ramesh, MS-MVP
The Documents folder is located at "%USERPROFILE%\Documents" path, which is:
C:\Users\{user}\Documents
Default Shell Folder Paths:
http://www.winhelponline.com/article...ows-Vista.html
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
The Winhelponline Blog: http://www.winhelponline.com/blog
Windows® Troubleshooting: http://www.winhelponline.com
> on
> my
> user profile.
> The R G
Old 06-15-2008   #7 (permalink)
Rpower
Thank you, I dont know why my computer came with the documents folder in such
a strange place (i guess it is because they did not even beta test this kind
of stuff prior to relese. Like vistas inability to unzip more than 1 zip
folder at a time without crashing ;( )
The R G
> Regards,
> > on
> > my
> > user profile.
> > The R G
Old 06-15-2008   #8 (permalink)
Malke
> my documents, downloads, music, etc. are located there.
If your computer *really* came with the Documents folder tucked inside the
Games folder and you didn't actually move it there by mistake and didn't
realize it (the most probable scenario), then your computer mftr.'s image
was faulty. This can happen (witness the intelppm.sys issue with XP SP2/3
as well as the very occasional bad image) although I've never seen this on
a computer from a major OEM (Dell, Sony, HP, Toshiba, Compaq, etc.).
I'm not particularly fond of Vista but you need to realize that this has
nothing to do with Vista or Microsoft. It's either you or the OEM.
Just sayin'.
Malke
MS-MVP
Elephant Boy Computers
www.elephantboycomputers.com
Don't Panic!
Old 08-16-2008   #9 (permalink)
David Leon
The default location should be C:\Users\<username>\Documents
You can change the location by right-clicking the folder and selecting the
Location tab.
Any programs using the old "My Documents" location are redirected through a
hidden (system) symbolic link.
> with
> on
> my
> user profile.
> The R G
finding path to an .exe file Vista file management
Batch-file not working: PATH-problem? Vista General
elegant way to get path and file name PowerShell
Error Message - File path Missing - Need Help to fix the Problem Vista General
BUG? (Test-Path $path -IsValid) and empty $path PowerShell
