Vista - Vista Home Premium Not Booting
Old 06-16-2008   #1 (permalink)
Hogman
I'm hoping someone will be able to help me as I'm banging my head against the
wall now!!
Booting my mates PC I get the following error:
!! 0xc0190036 !! 4336/91047 (nlscoremig.dll)
All I can do at this point is restart.
I have tried, booting to last know successful, using windows repair.
Thanks for any help
Old 06-16-2008   #2 (permalink)
Mark L. Ferguson
Re: Vista Home Premium Not Booting
If you mean the system will not "Restore to Factory Defaults", it's likely
that the hard drive is damaged beyond repair, and you should quit spending
energy on it. See what warrantee is available for the system. (or start
over on an install to a new drive)
Windows Vista Help What are the system recovery options in Windows Vista:
http://windowshelp.microsoft.com/Win...4be5e1033.mspx
click the Ratings button. Voting helps the web interface.
http://www.microsoft.com/wn3/locales...help_en-us.htm see ''rate a post''
Mark L. Ferguson
"Hogman" <Hogman@xxxxxx> wrote in message
news:4D110BE1-FE10-490E-BDF5-B3256823A6EB@xxxxxx
> the
> wall now!!
> Thanks for any help
Old 06-16-2008   #3 (permalink)
Hogman
I'm hoping I have got to the bottom of this.
It looks like when SP1 was being installed the PC was either shut down or
the battery ran out.
I have been able to use the retore point feature which took me back just
before SP1 was installed and it picked it back up, problem was I was running
off the battery and it ran out again before it was completed!
She is going to bring the AC adapter in tomorrow so I will have to try it
again!!
Watch this space!
> Mark L. Ferguson
> > the
> > wall now!!
> > Thanks for any help
Dual Booting with Vista Home Premium 32 Bit and Vista Ultimate 64-Bit Vista installation & setup
Vista Home PRemium Booting Problems Vista performance & maintenance
Booting Vista (Home Premium) Problem Vista General
window vista home premium booting problem Vista performance & maintenance
Dual Booting Vista Home Premium with XP Vista installation & setup
