RB
Vista - problems with cursor freezing
06-17-2008   #1
dwarner265
I bought an HP Pavilion desktop on May 10 and have recently been
having increasing problems with my cursor freezing and sometimes
triggering a "storm" of opening, fluttering boxes (start menu box,
task manager, etc.) I can sometimes cool it down with alt/cntrl/
delete/cancel. Sometimes it stops by itself. When the cursor is
stuck, I can also sometimes free it with this procedure, but sometimes
it won't budge and I have to manually shut the machine off. HP
helped me restore the computer, but the problem still exists -- plus I
am no longer able to activate AOL. I would like to know if anyone else
has had the freezing, fluttering problem and if you were able to
correct it. A friend urged me to get a Mac instead, but I like this
PC except for that. However, it is wearing me down.
Thanks.
06-17-2008   #2
Malke
Re: problems with cursor freezing
If the problem exists after a restore to factory condition, then this is
probably a hardware fault. You just bought the machine; return it
immediately for a working one.
Malke
MS-MVP
Elephant Boy Computers
www.elephantboycomputers.com
Don't Panic!
RB
Similar Threads for: problems with cursor freezing
Mouse cursor problems General Discussion
freezing problems General Discussion
Problems with PC Freezing Vista General
Windows mail - problems with jumping cursor Vista mail
Freezing problems NOT fixed on RC2! Vista hardware & devices
