1.    17 Jun 2008 #1
    TiTi Guest
    System Tray : serious ergonomical problems - constatations
    This post is the english version of what I post today on
    m.p.f.w.v.general entitled "System Tray : sérieux problème d'ergonomie -
    constatations".
    I would like to tell Microsoft that I discover some ergonomical glitches
    that annoy me in my every day use of vista. I now they are small things
    (compare to all the operating system), but it is really "aggravating"
    (not sure of the translation ^^) ; it does not gives a feeling of
    perfection.
    Here is my thoughts about 3 errors that should have been detected and
    that need a correction :
    -The volume adjustment is horrible when using the keyboard :
    It is really hard to obtain the desire sound level if your are looking
    for a specific value ; mainly because there is a bip every time you
    press a button (up/down) on your keyboard.
    For example if the sound is fixed at 20 and I want to increase it up to
    25, I have to press 5 times the upper arrow, which gives :
    bip bip biip biip biiiiip biiiiiiip ... and ... I'm lost ! All this
    "bip" made me loose control about where I was in terms of sound volume
    (number).
    Moreover the numeric value is not shown everytime : only on mouseover...
    -The alimentation mode does not apply until you clic elsewhere of the
    selection area. That differs from the sound adjustment (where you don't
    have to loose focus).
    -Again, about the little area where you chose the alimentation plan when
    you left clic on the battery icon in the system tray :
    The content of this area is not loaded during the computer start-up ,
    there is juste a white area :-(
    I've got a M1330 (good laptop, but aldready 1 year old), and still it is
    a pain in the ass when my system wakes up from prolonged sleep or simply
    start-up : I have to wait until complete load of the computer before i
    can change the alimentation plan.
    The problem happened a few times when I didn't pay attention to the
    current alimentation mode when I shutdown my computer : next time i
    start the computer it was in economic mode : only 1 core of the CPU,
    less power, slow start, obliged to wait for complete start-up before
    changing alimentation mode >.<
    To summarize : simple ergocomics details that need more attention in my
    opinion. It is unpleasant to find this kind of lakes into a so complete
    system...
    Hoping the feedback will be heard...
    TiTi
  2.    17 Jun 2008 #2
    Nonny Guest
    Re: System Tray : serious ergonomical problems - constatations
    It won't.
Add to System Tray
How can I add an item to the system tray so that when you click on it a pop up/window appears? Any advice/help is welcomed.
General Discussion
System tray
I used to have the icon in system try which looked like a bunch of bars that when right click on I could connect wireless to the internet which then...
Vista General
Odd system tray behaviour.
Occasionally I have noticed that certain icons can be missing on start-up from the systems tray (volume control etc). Usually restarting will remedy...
General Discussion
system tray
How do I turn off the icons in the system tray at the bottom right of screen, the number lock, scroll lock and caps lock? When I click on them...
General Discussion
System Tray/Explorer Problems.
OK so I just got an Acer Extensa 5420 with an AMD Turion 64 x2. It's 32bit Windows though, which is odd. Anyway, I have Vista Home Premium and lately...
Vista performance & maintenance
problems with system tray, etc.
I am using Windows Vista. In the system tray, the power, network, and volume icons have suddenly disappeared. They are also greyed out in "Taskbar...
Vista hardware & devices
Icon in system tray
I would like to know if there is a way of getting Windows Mail in the system tray so that you can leave it running like you do with Outlook. Thank...
Vista mail
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
