Vista - System Configuration Question
Old 06-18-2008   #1 (permalink)
smackedass
Hello,
With Windows XP, when you ran msconfig, and rebooted, you got that box with
the message about how your settings have changed, and at the bottom there
was a checkbox that said something to the extent of "Do not show this
message at startup".
With Vista, when you run msconfig and reboot, Windows Defender comes up and
gives you a message something to the extent of "Some programs have been
blocked, click here to see which programs or choose to unblock them".
(Again, I'm paraphrasing).
But now there's no easy, evident way to not make that message seen at
startup. Or is there? There must be, but I'm just not finding it?
Thanks in advance,
smackedass
Old 06-18-2008   #2 (permalink)
Mr. Arnold
Re: System Configuration Question
"smackedass" <kemanospamcomputer@xxxxxx> wrote in message
news:R846k.7704$LN.7135@xxxxxx
Quote:
> Hello,
> with the message about how your settings have changed, and at the bottom
> there was a checkbox that said something to the extent of "Do not show
> this message at startup".
> and gives you a message something to the extent of "Some programs have
> been blocked, click here to see which programs or choose to unblock them".
You should look at the WD section in the link and tell WD to allow the
programs in question to run at start-up. You may have to create short-cuts
or go to the exe and set Run as Administrator too, because the those
programs are being block because they need their privileges escalated.
Startup Programs - Enable or Disable
Old 06-18-2008   #3 (permalink)
smackedass
> programs in question to run at start-up. ...etc...
Exactly what I did NOT want to hear, but thanks anyway, thanks for
responding.
sa
Old 06-18-2008   #4 (permalink)
PaulM
I have a script here that will enable the prompt; Line 24.
http://www.paulsxp.com/tweaksvista.html
www.paulsxp.com
www.paulsxp.com/forum
news:eJd6k.5877$7A1.2069@xxxxxx
> responding.
> sa
Old 06-19-2008   #5 (permalink)
Dave-UK
"PaulM" <paul@xxxxxx> wrote in message
news:e7xLRKY0IHA.4040@xxxxxx
Thanks for the tweaks etc.
Maybe it's just me but I find your site really difficult to read. Why do you
use
black/blue text on a dark grey background?
The only way I can see clearly is to Edit > Select All to reverse all the
colours.
Old 06-19-2008   #6 (permalink)
Vista Ultimate SP1 32bit
if you right click the icon where the message is coming from and click run program this will disable the bubble from popping up
Old 06-19-2008   #7 (permalink)
Ramesh, MS-MVP
Windows Vista blocks startup programs that requires UAC elevation and that's
the reason you see the error message. There is a workaround though, using
Task Scheduler.
Fix for Windows has blocked some startup programs error in Windows Vista:
http://www.winhelponline.com/blog/fi...rograms-error/
See also:
Error message when you start a Windows Vista-based computer: "Windows has
blocked some startup programs":
http://support.microsoft.com/kb/930367
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
The Winhelponline Blog: http://www.winhelponline.com/blog
Windows® Troubleshooting: http://www.winhelponline.com
Quote:
> Hello,
> Thanks in advance,
> smackedass
Old 06-19-2008   #8 (permalink)
PaulM
I do not find it hard to read. What color would suggest?
www.paulsxp.com
"Dave-UK" <1@xxxxxx> wrote in message
news:9rmdnbVCzup0t8fV4p2dnAA@xxxxxx
> you use
> colours.
Old 06-19-2008   #9 (permalink)
Dave-UK
"PaulM" <paul@xxxxxx> wrote in message news:OQ2nouh0IHA.5472@xxxxxx
What's wrong with black text on a white background ?
Are you really happy with this layout ?
http://www.paulsxp.com/downloads.html
It gives me a headache looking at it. Perhaps I'm getting old.
It's your site so as long as you like it...
Old 06-19-2008   #10 (permalink)
Colin Barnhorst
Maybe you should have someone you know who has a color deficiency (aka color
blindness) take a look. I never thought about it but it makes sense to have
your own website checked for things like that. Just a thought.
> www.paulsxp.com
>> you use
>> colours.
Solved System Configuration question. General Discussion
Newbie VPC configuration Question Virtual PC
Virtual PC configuration question Virtual PC
ReadyBoost configuration Question Vista installation & setup
