| | Problems with disk cleanup I am looking to create space in my hard drive but i read on the forums somewhere that the disk cleanup process for vista can wipe all your programs and files of your computer. Is this true? Is their a flaw in the disk cleanup? and if i use it will my computer be safe? Thanks for all your help |
| | Re: Problems with disk cleanup There's various programs, both within Vista (and XP), or external utilities like TumeUp Utilities, which will SAFELY do disk clean-up. After - do a defrag. If in any doubt, do a full back-up first, or create a restore point. After many years of experience of clean-ups, both MS and others,, I've never experienced a problem clean-up that subsequently needed a "restore". What you COULD lose (depending on which clean-up utility you use) are the huge i9ncrement of "microsoft update" backup files, which are only ever needed if you install a security update and subsequently need to uninstall it - this would ususally be obvious within a couple of days of installation, so after that, these files are then redundant and can be deleted. Yes, your computer progs will be safe, barring external forces (power cut) - I have daily scheduled clean-ups, and no problems directly connected with it. "scottyjamison" <scottyjamison@xxxxxx> wrote in message news:BE4D4678-6CEF-4276-A865-3D4153AD8B5E@xxxxxx Quote: >I am looking to create space in my hard drive but i read on the forums > somewhere that the disk cleanup process for vista can wipe all your > programs > and files of your computer. Is this true? Is their a flaw in the disk > cleanup? and if i use it will my computer be safe? > > Thanks for all your help |
| | Re: Problems with disk cleanup > I am looking to create space in my hard drive but i read on the forums Quote: > somewhere that the disk cleanup process for vista can wipe all your programs > and files of your computer. Is this true? http://www.winhelponline.com/blog/se...-registration/ -- Met vriendelijke groet, Mark Veldhuis. |
| | Re: Problems with disk cleanup > i read on the forums Quote: > somewhere that the disk cleanup process for vista can wipe all your > programs > and files of your computer. Is this true? Is their a flaw in the disk > cleanup? and if i use it will my computer be safe? fundamental problem as that. The disk cleanup feature in Vista is perfectly safe, but you must read all the prompts so you know what you are asking it to do. SteveT |
| Disk Cleanup | General Discussion | |||
| Disk Cleanup Bug | Vista performance & maintenance | |||
| Disk Cleanup App | Vista General | |||
| Disk Cleanup Insane Problems | Vista General | |||
| Disk Defragmenting and Disk Cleanup | Vista hardware & devices | |||
