| | Help-How to sync two folders- one is in local driver and the other is in a USB removeable drive There is two folders-A and B which is a backeup folder of A. A: my documents folder, all my personal files are saved here. B: a folder in my USB storage. Anybody could help to figure out how to sync B with A? The Backup tool is a choice but it generates a compressed file that is not easy to open and read. Thank you. |
| | RE: Help-How to sync two folders- one is in local driver and the other you can make Folder B a Briefcase of Folder A. In you USB storage, right click -> New -> Briefcase open the briefcase drag files from Folder A in to Briefcase (Folder B) to synchronize, click update all "Damon" wrote: > There is two folders-A and B which is a backeup folder of A. > > A: my documents folder, all my personal files are saved here. > B: a folder in my USB storage. > > Anybody could help to figure out how to sync B with A? > > The Backup tool is a choice but it generates a compressed file that is not > easy to open and read. > > Thank you. > > |
| using removeable hard drive trays with Vista Home Premium x64 | General Discussion | |||
| No removeable drive F | Vista file management | |||
| removeable hard drive for OS Vista ->XP pro | Vista hardware & devices | |||
| Sync Local Folders | Vista mail | |||
