Vista - Power Point View
Old 06-18-2008   #1 (permalink)
Elaine
Power Point View
Not sure if this is the correct place to post, but I can not get PP viewer
to work. New computer running Vista, I downloaded the viewer and when I
click on a link it comes up with the message to make sure it is linked to
the correct program. I have gone into default assoc and PPS is connected to
Power Point Viewer. It worked on XP Pro computer, what do I need to do?
Have restarted after downloading thinking maybe that would work. Nada
tks
elaine
Old 06-19-2008   #2 (permalink)
TDM
Re: Power Point View
"Elaine" <pepk@xxxxxx> wrote in message
news:ebVjnKW0IHA.3756@xxxxxx
> to Power Point Viewer. It worked on XP Pro computer, what do I need to
> do? Have restarted after downloading thinking maybe that would work. Nada
> tks
> elaine
Elaine,
Have you tried to run the PP Viewer install in XP compatability mode
from Vista ?
TDM
Old 06-19-2008   #3 (permalink)
Whippet
Check this site:
http://www.winhelponline.com/article...ows-Vista.html
Follow instructions. Worked for me.
"TDM" <rpuffd@xxxxxx> wrote in message
news:OqR7Jnj0IHA.800@xxxxxx
>> viewer to work. New computer running Vista, I downloaded the viewer and
>> when I click on a link it comes up with the message to make sure it is
>> linked to the correct program. I have gone into default assoc and PPS is
>> connected to Power Point Viewer. It worked on XP Pro computer, what do I
>> need to do? Have restarted after downloading thinking maybe that would
>> work. Nada
>> tks
>> elaine
> Elaine,
> from Vista ?
> TDM
Old 06-19-2008   #4 (permalink)
Whippet
Try this:
>> work. Nada
>> tks
>> elaine
> Elaine,
> from Vista ?
> TDM
Old 06-20-2008   #5 (permalink)
Elaine
Re: Power Point Viewer
When I go to reg, I don't have the part \shelf\Show. Mine stops after 11.
elaine
POWER POINT Vista mail
Power point Vista General
power point Vista General
power point Vista mail
can't view power point Vista mail
