Vista - Smooth sound device change
Old 06-18-2008   #1 (permalink)
RealCat
I have a USB headset, which has a built-in sound card (Microsoft
LifeChat). When I plug this into one of the USB ports of my pc,
Windows automatically switches the default playback device to it, and
when I unplug it, Windows switches back to the PCI sound card. The
problem is, that when I unplug the USB headset, all the sound play
stops, Windows Media Player shows an error message, and I have to
restart applications to reflect the changed default sound device.
I once had installed the OS X (a hacked version that runs on Intel PC)
on my computer (the same hardware), and found unplugging the USB
headset (the same Microsoft LifeChat) didn't interrupt playback. In
fact, all sound play smoothly switched to the PCI sound card so I
could continue to listen to it from my speakers.
Since I ran OS X on the same machine, this feature is not from
hardware, but software. Is this feature unavailable on Windows Vista?
sound device Vista hardware & devices
No sound device Vista performance & maintenance
Sound device: do I have it or not? Vista hardware & devices
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
No sound device Vista hardware & devices
