Vista 32bit Enterprise BSOD, need help please
  1. #1
    helpmark Guest
    Hi everyone,
    Specs: I am running Windows Vista 32 bit Enterprise Edition, with all
    critical/required Updates from Windows Update.
    I recently purchased a Vista laptop, and I had some troubles with it
    recently (read:as soon as I got it). Problem is I purchased it new off
    of eBay, so I can't send it back for a new one .
    I was getting a system file corrupt or missing error, and I fixed that
    by copying the corrupt file from the recovery disk to the hard drive
    through the command prompt.
    Well, after that problem disappeared, this new one appeared with which
    I am at a loss.
    What happens is whenever I boot up the laptop, It will advance just
    past the Vista loading screen, and as the sign in screen is about to
    appear, I get a BSoD:
    STOP: c0000145 {Application Error}
    The application failed to initialize properly (0xc0000005)
    And that's it. The BSoD is extremely fustrating because it does not
    tell me WHICH application is causing the error.
    Now onto the interesting part--When I get this error, I have no choice
    but to power off again. The next time I try and boot up again, the
    everything loads up fine. If I shut down and try and boot up again...
    the same error as before appears. Again, if I reboot from this point,
    everything boots up fine, and the cycle repeats.
    So basically, it seems that I can load Vista EVERY OTHER time... which
    to me is incredibly bizzare, because if I am able to turn Vista on once,
    shouldn't Vista try and boot up the same way every time?
    Edit: Here's a list of all the software I installed after receiving the
    laptop( which may or may not have affected this error):
    Firefox 3.0,
    Steam, OrangeBox,
    VideoLAN (VLC player),
    IrfanView,
    Adobe Flash Player for Firefox and IE.
    Also, I had installed python 2.5 ('Python Programming Language --
    Official Website' (http://www.python.org)) and the pygame library, but I
    removed them, thinking they were the problem (not the case it seems)
    Does anyone have any suggestions about this problem?
    I've heard that it could be a memory problem, so I ran windows memory
    test, and I didn't find any errors. I'm running MemTest86 right now just
    to make sure.
    Could it also be that my memory isn't seated properly? Thanks.
  2. #2
    Earle Horton Guest
    Re: Vista 32bit Enterprise BSOD, need help please
    Have you tried System Restore, backing up to a happier time? Do you have
    any suspicious devices plugged in, such as a USB device? The symptoms point
    to a device initialization routine. Unless you can figure something out, a
    clean install seems like a good bet.
    Cheers,
    Earle
    "helpmark" <helpmark.3baa5g@xxxxxx> wrote in message
    news:helpmark.3baa5g@xxxxxx
    > Hi everyone,
    > I am at a loss.
    > Firefox 3.0,
    > Steam, OrangeBox,
    > IrfanView,
    > to make sure.
  3. #3
    Mick Murphy Guest
    RE: Vista 32bit Enterprise BSOD, need help please
    Have you tried tapping F8 at Startup, and going to the list of Safe Mode, etc?
    There is a provision there, so that you can find out what the Blue Screen
    error message is.
    I forget the exact words, but it is to do with the fact that you don't auto
    restart after that error message.
    Mick Murphy - Qld - Australia
    "helpmark" wrote:
    > Hi everyone,
    > I am at a loss.
    > Firefox 3.0,
    > Steam, OrangeBox,
    > IrfanView,
    > to make sure.
  4. #4
    helpmark Guest
    Ok, strange occurence, but I fixed it by installing vista sp1
    And I did try tapping F8 at startup, but nothing happened. It's because
    for some strange reason my laptop uses F10 instead of F8.
    Anyways, thanks everyone for the help!
  5. #5
    stanlyden Guest
    I have had exactly the same happen to my system over the last week or so
    and have not been able to get any advice to get me back into the system.
    I've posted a thread about it here:
    'Vista won't load and blue screen comes up. - Tech Support Guy Forums'
    (http://tinyurl.com/6965nh)
    Maybe some of the other information provided in the thread may be of
    use to you? I don't think I'll be seeing an answer anytime soon! Will
    just have to wait until someone actually finds a way around this! Good
    luck with it all though and if you manage to find any useful solutions
    let me know pls )
Vista 32bit Enterprise BSOD, need help please problems?
Re: 2008 Enterprise 32bit no memory after Upgrade Matija Kapraljevic [Revenger] Server General 0 08 Feb 2010
Debugging the Cause of a BSOD on Vista Home 32bit Jeff91 Vista General 1 09 Dec 2009
BSOD with Vista Ultimate 32bit chickmagloor Vista hardware & devices 0 04 Mar 2009
VIsta 32bit random BSOD Quacho-1 Vista performance & maintenance 0 15 Jan 2009
Vista 32bit BSOD zacmccormick Vista hardware & devices 2 01 May 2008
