| | Vista Copy Speed over the network is slower that XP SP2 and OSX..much slower? We have a client with a new Vista Business x64 Workstation joined to a 2003 (native) AD domain. The hardware specs are first class (64GB RAM, Dual Qaud core 3+GHz Intel Procs, Fastest SATA disks available, 2 Uber Graphics card in SLI, Giabit NIC, etc.). This machine must move large amounts of data to a File Server's SAN frequently (hundreds of gigs per upload or download). The problem is uploads and downloads to this file server via mapped drive in Vista take considerably longer than either an XP Pro SP2 or MacBook Pro from THE SAME network jack. What we have done so far with minimal improvements if any: 1. Disabled active AV scanning on the file server and removed it completely on the Vista workstation (were using Trend Micro). 2. Disabled "Remote Differential Compression". 3. Disabled SMB 2.0 via registry ***at this point the file transfer calculation seemed to start working correctly, previously it would estimate it would take 4+ hours to copy 85Gb of test data when in reality it was finished much much sooner (several minutes but forget the exact number now)*** Client reported some speed improvements at this point but not that great. From the file server during the transfer (when this is the only transfer happening on the network) the Gigabit NIC on the server reports a network utilization of 30-40%. The entire building is wired with Fiber. The file server and SAN are connected to a Black Diamond switch with a 1-2GB fiber blade. The workstation is connected to a Allied Telesyn Media converter via copper/ethernet gigabit connection (media converter routed to same fiber blade). Next week Im going to do some bench marking with different operating systems, data, connections etc. I need to find a fiber card that has Vista x64 drivers and see if that helps. Any ideas on how I can improve this transfer speed? Thanks in Advance! Sam |
| | Re: Vista Copy Speed over the network is slower that XP SP2 and OS X..much slower? "Sam" <samuel.ali@xxxxxx> wrote in message news:21ed956b-44d5-4ed6-b5b7-71b07be729fd@xxxxxx Quote: > We have a client with a new Vista Business x64 Workstation joined to a > 2003 (native) AD domain. The hardware specs are first class (64GB > RAM, Dual Qaud core 3+GHz Intel Procs, Fastest SATA disks available, > 2 Uber Graphics card in SLI, Giabit NIC, etc.). This machine must move > large amounts of data to a File Server's SAN frequently (hundreds of > gigs per upload or download). The problem is uploads and downloads to > this file server via mapped drive in Vista take considerably longer > than either an XP Pro SP2 or MacBook Pro from THE SAME network jack. > > What we have done so far with minimal improvements if any: > 1. Disabled active AV scanning on the file server and removed it > completely on the Vista workstation (were using Trend Micro). > 2. Disabled "Remote Differential Compression". > 3. Disabled SMB 2.0 via registry > ***at this point the file transfer calculation seemed to start working > correctly, previously it would estimate it would take 4+ hours to copy > 85Gb of test data when in reality it was finished much much sooner > (several minutes but forget the exact number now)*** Client reported > some speed improvements at this point but not that great. From the > file server during the transfer (when this is the only transfer > happening on the network) the Gigabit NIC on the server reports a > network utilization of 30-40%. > > The entire building is wired with Fiber. The file server and SAN are > connected to a Black Diamond switch with a 1-2GB fiber blade. The > workstation is connected to a Allied Telesyn Media converter via > copper/ethernet gigabit connection (media converter routed to same > fiber blade). > > Next week Im going to do some bench marking with different operating > systems, data, connections etc. I need to find a fiber card that has > Vista x64 drivers and see if that helps. > > Any ideas on how I can improve this transfer speed? > > Thanks in Advance! > > Sam any real improvement. But will watch this thread closely though as to me, this is one of Vista's major and serious faults. |
| | Re: Vista Copy Speed over the network is slower that XP SP2 and OS X..much slower? Make sure to install SP1, then see the following: Bring network files closer: http://blogs.zdnet.com/Bott/?p=479&page=5 Also, visit: http://www.diskeeper.com/products/do...umentation.asp and click on "Disk Performance Analyzer for Networks". -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows Vista Enthusiast --------------------------------------------------------------- "Sam" <samuel.ali@xxxxxx> wrote in message news:21ed956b-44d5-4ed6-b5b7-71b07be729fd@xxxxxx We have a client with a new Vista Business x64 Workstation joined to a 2003 (native) AD domain. The hardware specs are first class (64GB RAM, Dual Qaud core 3+GHz Intel Procs, Fastest SATA disks available, 2 Uber Graphics card in SLI, Giabit NIC, etc.). This machine must move large amounts of data to a File Server's SAN frequently (hundreds of gigs per upload or download). The problem is uploads and downloads to this file server via mapped drive in Vista take considerably longer than either an XP Pro SP2 or MacBook Pro from THE SAME network jack. What we have done so far with minimal improvements if any: 1. Disabled active AV scanning on the file server and removed it completely on the Vista workstation (were using Trend Micro). 2. Disabled "Remote Differential Compression". 3. Disabled SMB 2.0 via registry ***at this point the file transfer calculation seemed to start working correctly, previously it would estimate it would take 4+ hours to copy 85Gb of test data when in reality it was finished much much sooner (several minutes but forget the exact number now)*** Client reported some speed improvements at this point but not that great. From the file server during the transfer (when this is the only transfer happening on the network) the Gigabit NIC on the server reports a network utilization of 30-40%. The entire building is wired with Fiber. The file server and SAN are connected to a Black Diamond switch with a 1-2GB fiber blade. The workstation is connected to a Allied Telesyn Media converter via copper/ethernet gigabit connection (media converter routed to same fiber blade). Next week Im going to do some bench marking with different operating systems, data, connections etc. I need to find a fiber card that has Vista x64 drivers and see if that helps. Any ideas on how I can improve this transfer speed? Thanks in Advance! Sam |
| | Re: Vista Copy Speed over the network is slower that XP SP2 and OS X..much slower? "Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message news:u$1fCiv0IHA.4948@xxxxxx Quote: > Make sure to install SP1, then see the following: > > Bring network files closer: > http://blogs.zdnet.com/Bott/?p=479&page=5 > > Also, visit: > http://www.diskeeper.com/products/do...umentation.asp > and click on "Disk Performance Analyzer for Networks". |
| | Re: Vista Copy Speed over the network is slower that XP SP2 and OSX..much slower? Carey, The only difference between mapped drives and shortcuts as described in the zdnet article is the ability to use more descriptive names, right? Is there a performance benefit from using a shortcut instead of mapped drive (as our client is accustomed to mapped drives)? Im going to give the "Disk Performance Analyzer for Networks" a shot on Monday. Thanks! Sam On Jun 20, 10:10 am, "Carey Frisch [MVP]" <cnfri...@xxxxxx> wrote: Quote: > Make sure to install SP1, then see the following: > > Bring network files closer:http://blogs.zdnet.com/Bott/?p=479&page=5 > > Also, visit:http://www.diskeeper.com/products/do...umentation.asp > and click on "Disk Performance Analyzer for Networks". > > -- > Carey Frisch > Microsoft MVP > Windows Desktop Experience - > Windows Vista Enthusiast |
| | #6 (permalink) |
| | Re: Vista Copy Speed over the network is slower that XP SP2 and OS Diskeeper 2008 has more powerful defragmentation engines. The “brains” behind Diskeeper 2008 contain an intelligent defrag function that detects volume and system conditions (e.g. low free space or heavy fragmentation) and dynamically chooses the most effective software engine to net performance gains on that system. This takes place automatically, on the fly, in real time. -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows System & Performance "Canuck57" wrote: Quote: > > "Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message > news:u$1fCiv0IHA.4948@xxxxxx Quote: > > Make sure to install SP1, then see the following: > > > > Bring network files closer: > > http://blogs.zdnet.com/Bott/?p=479&page=5 > > > > Also, visit: > > http://www.diskeeper.com/products/do...umentation.asp > > and click on "Disk Performance Analyzer for Networks". > I thought Vista defragged itself? Or is that broken too? > > > |
| | #7 (permalink) |
| | Re: Vista Copy Speed over the network is slower that XP SP2 and OS > Diskeeper 2008 has more powerful defragmentation engines. The “brains” Quote: > behind > Diskeeper 2008 contain an intelligent defrag function that detects volume > and > system conditions (e.g. low free space or heavy fragmentation) and > dynamically chooses the most effective software engine to net performance > gains on that system. This takes place automatically, on the fly, in real > time. bull****. How naive. SteveT |
| | #8 (permalink) |
| | Re: Vista Copy Speed over the network is slower that XP SP2 and OS "Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message news:805393B0-EEA8-42A6-BDBA-9FB73DA3A7F7@xxxxxx Quote: > Diskeeper 2008 has more powerful defragmentation engines. The "brains" > behind > Diskeeper 2008 contain an intelligent defrag function that detects volume > and > system conditions (e.g. low free space or heavy fragmentation) and > dynamically chooses the most effective software engine to net performance > gains on that system. This takes place automatically, on the fly, in real > time. Defrag is defrag. Put the disk blocks in sequence that can be read faster. Not much else to it. What a digression, even Win95 defragged. Hopefully Win7 will be advanced enough not to need a defrag, like all the other OSes. Sorry, I can't resist the dig here as Vista should do this without the need for a third party product. Next issue, I too have the problem with copy in. Now I can't see a SATA 150 being slower than a 100BT. So what is the hold up? My Vista's own performance meter can't seem to go much past 5mbs. Don't say it is network, as without a cable change using Linux that goes to 100mbs, just under 20 times faster. |
| | #9 (permalink) |
| | Re: Vista Copy Speed over the network is slower that XP SP2 and OSX..much slower? He are the results of my testing. It is a Vista while playing music issue it seems. Doesnt matter if said music is located locally or on the network. Or being played with WinAmp or iTunes. Same results with Vista32 and Vista64, Fiber and Copper (1GB). XP or OS X are not affected. Streaming audio from file servers and locally would be considered "business critical" in this environment. TO MACHINE OS Fiber to BD Copper to BD Notes MEDIA100 XP VEGA VISTA Business x64 1:25 to C After BIOS and NIC driver update. No running apps. VEGA VISTA Business x64 5:35 to C Winamp Playing music from Nicolo Orion32 XP SP2 2-3 minutes to C 1GB nForce Controller (NIC). No Music. Orion32 XP SP2 2 minutes to C WinApm playing music from Nicolo VEGA VISTA Business x64 5:30 (via 3Com 1GB fiber card) to C After ExtremeWare (BD) update to 7.7. Playing local music from C drive. VEGA VISTA Business x64 Less than 1 minute to C No apps running VEGA VISTA Business x64 5:30 to C Playing music from Nicolo. VEGA VISTA Business x64 1:20 to D No music playing VEGA VISTA Business x64 Less than 1 minute to C No music (other apps running) VEGA VISTA Business x64 5:40 to C WinAmp playing music from Nicolo. PhotoStudio Mac OS X 1:30 to C No music playing Vega VISTA Business x64 Less than 1 minute No Music ALI-LAP Vista Business x86 1:55 to C No music ALI-LAP Vista Business x86 4:20 to C Music playing from Nicolo ALI-LAP Vista Business x86 4:20 to C Music playing from local disk ( C ) MEDIA100 XP 1-2 minutes to C No music playing MEDIA100 XP 1-2 minutes to C Music playing from Nicolo On Jun 20, 9:51 am, Sam <samuel....@xxxxxx> wrote: Quote: > We have a client with a new Vista Business x64 Workstation joined to a > 2003 (native) AD domain. The hardware specs are first class (64GB > RAM, Dual Qaud core 3+GHz Intel Procs, Fastest SATA disks available, > 2 Uber Graphics card in SLI, Giabit NIC, etc.). This machine must move > large amounts of data to a File Server's SAN frequently (hundreds of > gigs per upload or download). The problem is uploads and downloads to > this file server via mapped drive in Vista take considerably longer > than either an XP Pro SP2 or MacBook Pro from THE SAME network jack. > > What we have done so far with minimal improvements if any: > 1. Disabled active AV scanning on the file server and removed it > completely on the Vista workstation (were using Trend Micro). > 2. Disabled "Remote Differential Compression". > 3. Disabled SMB 2.0 via registry > ***at this point the file transfer calculation seemed to start working > correctly, previously it would estimate it would take 4+ hours to copy > 85Gb of test data when in reality it was finished much much sooner > (several minutes but forget the exact number now)*** Client reported > some speed improvements at this point but not that great. From the > file server during the transfer (when this is the only transfer > happening on the network) the Gigabit NIC on the server reports a > network utilization of 30-40%. > > The entire building is wired with Fiber. The file server and SAN are > connected to a Black Diamond switch with a 1-2GB fiber blade. The > workstation is connected to a Allied Telesyn Media converter via > copper/ethernet gigabit connection (media converter routed to same > fiber blade). > > Next week Im going to do some bench marking with different operating > systems, data, connections etc. I need to find a fiber card that has > Vista x64 drivers and see if that helps. > > Any ideas on how I can improve this transfer speed? > > Thanks in Advance! > > Sam |
| About a slower Internet speed. | Network & Sharing | |||
| download speed much slower than should be | Vista networking & sharing | |||
| Vista Copy Speed over the network is slower that XP SP2 and OSX..much slower? | Vista networking & sharing | |||
| Vista machine getting slower and slower everyday | Vista General | |||
| vista slower and slower startup | Vista performance & maintenance | |||
