Vista - Backup and restore center problems
Old 06-21-2008   #1 (permalink)
edspyhill01
1) How do I completely cancel a backup? I started one a few days ago
and each time I try to start a new backup of just my home directory
the old one starts up again. I'm backing up to the DVD drive.
2) Is there a way to select specific directory trees or even just a
folder?
3) Can anyone recommend a third party backup package?
Old 06-21-2008   #2 (permalink)
Mick Murphy
RE: Backup and restore center problems
Acronis True Image to back up your whole System.
Mick Murphy - Qld - Australia
> folder?
Old 06-21-2008   #3 (permalink)
edspyhill01
Re: Backup and restore center problems
How do I completely cancel a backup? I started one a few days ago and
each time I try to start a new backup of just my home directory the
old backup starts up again and asks for DVD 3. I'm backing up to the
DVD drive.
Solved Backup and Restore Center General Discussion
vista pc restore (Backup and Restore Center) Vista performance & maintenance
Backup and Restore Center problems? Vista General
backup and restore center Vista General
