Vista - Wireless mouse and the ole screen saver issue
Old 06-24-2008   #1 (permalink)
borninusa
Okay..I know this has been discussed before...but my question is a bit
extended from earlier discussions.
I bought a Logitech mouse...and now on my Vista operated machine...the
screen saver does not always come on.
Upon reading earlier post..it was said I needed to go into updates to find
the "HID non-user input data filter"..and install. Well, updates never found
it nor is it a part of a previous update that I have done. After much
looking, I found the update on the microsoft webpage. I was able to download
it.
It is an .cab extension file. I had downloaded TurboZip to extract the .cab
file since nothing I had does that.
My question is..where the heck do I extract it to? I dont want to assume
anything so I thought I would ask.
Any thoughts are appreciated.
screen saver not working - microsoft wireless mouse Vista General
Screen saver not working (and I'm NOT using wireless mouse or keyb Vista General
Screen saver not working no wireless mouse Vista General
Wireless Mouse Prevents Screen Saver? Vista General
Wireless Mouse against Screen Saver Vista performance & maintenance
