| | Vista S3 resume from sleep problem Hi, My Vista 64 machine (Gigabyte GA-X48-DS5 mobo, Q6600 cpu, 8GB ram, Radeon HD2400 vga card) has a problem when it resumes from sleep. There is a protracted (3 seconds) buzzing noise and then the display shows a vertical pattern of narrow red and white stripes and the machine hangs. Only a reset will get it to reboot - the keyboard is completely dead. Any advice ? Thanks, Mike |
| | Re: Vista S3 resume from sleep problem I should say that there is an installation of XP Pro 32 on the same machine which resumes without problem. Mike |
| | Re: Vista S3 resume from sleep problem Update your drivers. I had a similar problem with a different motherboard and a Radeon 3450, resolved when Catalyst 8.6 was installed. "Mike" <mikedavies621@xxxxxx> wrote in message news:ed1beb40-5b4f-4f0d-a741-511849fd9f83@xxxxxx Quote: > Hi, > > My Vista 64 machine (Gigabyte GA-X48-DS5 mobo, Q6600 cpu, 8GB ram, > Radeon HD2400 vga card) has a problem when it resumes from sleep. > There is a protracted (3 seconds) buzzing noise and then the display > shows a vertical pattern of narrow red and white stripes and the > machine hangs. Only a reset will get it to reboot - the keyboard is > completely dead. > > Any advice ? > > Thanks, > > Mike |
| | Re: Vista S3 resume from sleep problem > Update your drivers. I had a similar problem with a different motherboard Quote: > and a Radeon 3450, resolved when Catalyst 8.6 was installed. version of the drivers for this card. Thanks, Mike |
| | Re: Vista S3 resume from sleep problem "Dominic Payer" <dcp@xxxxxx> wrote in message news 9B3603A-63B3-4B98-853C-824CAE80B0E8@xxxxxxQuote: GFX drivers and then see what Windows update says.. sometimes you can get a Microsoft driver that will be more stable (in my experience) but not as good performace wise- so the best bet is to go for ATI. Marc |
| | #6 (permalink) |
| | Re: Vista S3 resume from sleep problem Well, I downloaded version 8.6 of the ATI driver suite and that has indeed fixed my problem. Many thanks to all who replied, Mike |
| Vista keeps forgetting ReadyBoost after Resume from Sleep | Vista performance & maintenance | |||
| Vista Won't Sleep and successfully resume. | Vista General | |||
| Vista Won't Resume from sleep. | Vista General | |||
| Weather Gadget problem with Sleep & Resume | Vista General | |||
| Problem with resume (from S3 standby/sleep) | Vista General | |||
