Vista Tutorial - 2 different vista problems. Memory dump crash and startup repair cannot fix problems
Old 06-25-2008   #1 (permalink)
Newbie
Vista Home Edition
Hi everybody ,
I am new here. I am a simple Vista user who is having 2 different problems one in my laptop and one on my desktop.
Desktop ( acer AL1916W) We recently updated 2*2 GB memory and ever since we constantly get the memory crash blue screen everytime we start the computer up. After it restarts it goes prefectly ok and we dont have this error untill the next time we start up. Blue screen mentions something about disabling memory shadowin in th BIOS but I cannot see any memory option in the BIOS.
Laptop (Acer Aspire 5520) Last week it has been attemping some updates and for some reason one o more of them didnt work so it tried and tried everytime it was started up until yesterday. Again it shut down to configurate updates and... it never started up again. I have tried al the repair sistem, recovery options save mode... nothing works. Startup repair cannot fix the porblem. I have the whole sequence of data reported in the error detail( Startuprepairv2, autofailover...etc if needed)
My question is, is there any guide I can follow to fix both problems? and particulary about the laptop is there a way I can access the vista files in the hidden partition so that vista error can be repair and I do not loose all the info?
Many thanks in advance!
Old 06-25-2008   #2 (permalink)
Hiren
Guest
Re: 2 different vista problems. Memory dump crash and startup repair cannot fix problems
Yes,more information will indeed be highly beneficial.Please provide details
about the error reported in the lap-top.
"Hiera" <guest@xxxxxx-email.com> wrote in message
news:e4f924b1af5a2d8cad91a33e6e88f028@xxxxxx-gateway.com...
Hi everybody ,
needed)
Hiera
Old 06-25-2008   #3 (permalink)
Newbie
Vista Home Edition
Hi Hiren,
this is what the details show:
Problem event name: StartupRepair v2
Problem signature 01: Autofailover
Problem signature 02 : 6.0.6000.16386.60.6000.16386
Problem signature 03 : 5
Problem signature 04: 1048592
Problem signature 05: corrupt file
Problem signature 06: corrupt file
Problem signature 07 : 3221225624
Problem signature 08: 2
Problem signature 09: System Restore
Problem signature 10: 0
OS version: 6.0.6000.2.0.0.256.1
Local ID 1033
Old 06-25-2008   #4 (permalink)
Mick Murphy
Guest
http://www.knoppix.net/
RE Laptop: above is a link to download Knoppix Live CD ISO file for you to
make a bootable CD from to recover your Data.
It does not install on your Hard Drive; it uses your RAM and Graphics.
You can copy your Data to a flash Drive, using it to find your files..
If you use an F Key opton at BIOS screen at startup to Recover, it takes it
back to factory standards, whererby you lose ALL data and Programs that you
have installed.
Save your DATA using Knoppix, THEN do a Recovery via that way.!
Mick Murphy - Qld - Australia
"Hiera" wrote:
Quote:
> Hi Hiren,
> Local ID 1033
> Hiera
Old 06-28-2008   #5 (permalink)
Newbie
Vista Home Edition
Sorry for late reply.
That will do. I will make a copy of the files and do the recover.
Thanks a lot for your help!!
vista 32 cannot/will not repair/boot/solve the world's problems General Discussion
"Startup Repair" loop and graphics card problems General Discussion
bluescreen with memory dump on startup Vista General
Startup repair problems Vista installation & setup
Can't Start Vista, and problems with Startup Repair! Vista General
