Vista - Sound drivers... signing issues
Old 09-11-2006   #1 (permalink)
timske
Ok using an Abit kn-8, x2-4400@2.6, gig of ram, AND
onboad sound which is realtek, and HDA-digital x-mystique.
I cant get either of them to install the drivers. I am assuming its a
driver signing issue, the workaround to disable that function doesnt
seem to be working on RC-1. OS runs great other than I cant get sound
cards installed. The drivers for the HDA should work(they did before)
... if I can get them installed.
Anyone know of some workarounds for this or just any ideas at all ?
I've tried doing it all by inf files, turning off driver signing (which
i dont think works in rc-1) removing the hardware and all items and
starting fresh ect.
If I try to let windows install them it just says the drivers are
installed correctly already ... which is odd seeing as how its listed
in windows as missing the drivers :P
timske
timske's Profile: http://www.64bit-world.com/forums/member.php?u=2607
View this thread: http://www.64bit-world.com/forums/sh...ad.php?t=44314
Fresh install and updated sound drivers still no 5.1 sound :( Sound & Audio
Sound issues Vista General
Sound issues! Vista Games
How do I fix driver signing issues in Windows Vista Ultimate? Vista General
Sound blaster Updated Sound Card Drivers Vista General
